10-31-2014, 14:19 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2018005 Status: Offline Thanks Meter: 3 | HTC 8x pm23200 riff box error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC 8X (PM2320000) V1.0.5150.226] Connecting to the dead body...OK Detected dead body ID: 0x707910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
02-19-2015, 12:07 | #3 (permalink) |
Guest
Posts: n/a
Member: | Hello Brother, Need some Help! HTC 8x Dead while update with NBH stuck on 1% and then Battery Down Now phone just Detect as QDLOAD Only and on RIFF JTAG: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC 8X (PM2320000) V1.0.5150.226] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Try with other Models and ignore model id also but still same results! Thanks for Your Fast Support |
