03-28-2015, 10:17 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Lahore
Member: 144944 Status: Offline Thanks Meter: 53 | ~~~ HTC 8x PM2331000 (Resurrection Error) ~~~ Need some Help in this case: HTC 8x PM2331000 Model Resurrection Error Here is LOG: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC 8X (PM2331000) V1.0.5280.13411] Connecting to the dead body...OK Detected dead body ID: 0x706B50E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x006F (M MOR, 0x000008000000 Bytes = 128.00 MB) ERROR: Read Failed with Error Code: 0x46. Terminating at 0x000003F00000 No Resurrection Data is available for the eMMC Chip with Capacity = 131072KB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14,56GB Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover... |
03-28-2015, 10:32 | #2 (permalink) |
Member: 144944 Status: Offline Thanks Meter: 53 | And This is JTAG Analyze Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC 8X (PM2331000) V1.0.5280.13411] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4F1F0F0F, IR Length = 0x04 bits Device on TAP #1: ID = 0x706B50E1, IR Length = 0x0B bits Total IR length: 0x000F bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x706B50E1: Qualcomm MSM8960, H/W Rev. #7 |
03-28-2015, 13:30 | #3 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 57
Member: 1564612 Status: Offline Thanks Meter: 12,343 | bro, F.A.Q. there are for to be read: Quote:
allumts | ||
03-30-2015, 08:05 | #4 (permalink) |
Member: 144944 Status: Offline Thanks Meter: 53 | Yes Bro You Are Right thats why i posted this thread its because of HTC 8x Crap Multi Models Infect the real problem it was Security Unlocked Refurbished Model That is the reason it got stuck into QDLoad Mode due to wrong Firmware Attempt Now we need to correct DLL script to Handle Specific eMMC Version Hope some way out for this problem! Thanks for Reply |
03-31-2015, 15:14 | #5 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If eMMc is ok and not is broken...with Linux SO having right Unbrick eMMc file can restore...use google and must need a little of knowledge about LINUX SO.... I've seen that Legjia have answered that is eMMc broken and need of replace... You can only try with Linux...but is only one attempt.... BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
