02-19-2015, 12:16 | #1 (permalink) |
Guest
Posts: n/a
Member: | HTC 8x PMP23200 No Response Error Need some Help! HTC 8x Dead while update with NBH stuck on 1% and then Battery Down Now phone just Detect as QDLOAD Only and on RIFF JTAG: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC 8X (PM2320000) V1.0.5150.226] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Try with other Models and ignore model id also but still same results! Thanks for Your Fast Support |
02-19-2015, 13:00 | #2 (permalink) |
Guest
Posts: n/a
Member: | i repair this phone one day before with RIFF BOX then today flash with RUU_ACCORD_U_APO_00_hTC_Asia_WWE_2.00.707.01_1.11b .32.19.23_2_15.42.32_RETAIL_ENC_RELEASE Phone stuck on 1% and then battery low and phone turn off now just connect PC with QDLoader Driver only and above post RIFF JTAG Log ONLY! BABAK NURI and LEGIJA Brother what you say about this? and i think its Developers Version Because when it was alive then Security Unlocked and SuperCID and also see on internet Body ID : 0x407910E1 is related to PM2320001 Now come to remote client and check the problem also there is a user which has 512MB Backup of this MID Thanks for your Support |
