07-15-2013, 14:50 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: rajasthan
Member: 597610 Status: Offline Thanks Meter: 50 | Htc chacha a810e (ph06110) which probelm team help mmmmmmmmmmmmmmmmmmmmmmmmmmmm |
07-16-2013, 01:05 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Can You Tell Me About Phone History...? Also Did You Select All Option in Resurrector Window...?? You Have 2 Way: 1-Full erase Then Resurrect 2-Writing Full Dump File If Phone Have a Fine HW,Must Be Power On |
07-16-2013, 08:19 | #3 (permalink) |
Member: 597610 Status: Offline Thanks Meter: 50 | phone is blinking htc logo show,i manunal Resurrector optaion full erase then Resurrect but i can't write dump file.............. please link for full dump file |
07-17-2013, 07:45 | #6 (permalink) |
Member: 597610 Status: Offline Thanks Meter: 50 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [HTC ChaCha (PH0611000) V1.0.4745.47461] Connecting to the dead body...OK Detected dead body ID: 0x503C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! CAN Y CHEK ONLINE I GIVE T.VIVER ID |
07-17-2013, 07:59 | #7 (permalink) |
Member: 597610 Status: Offline Thanks Meter: 50 | AND ERASE LOGS Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [HTC ChaCha (PH0611000) V1.0.4745.47461] Connecting to the dead body...OK Detected dead body ID: 0x503C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x05010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x000016680000. Attempt to Repeat again. WARNING: Erasing Error (0x24) at 0x000016680000. Attempt to Repeat again. WARNING: Erasing Error (0x24) at 0x000016680000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00001D3C0000 is Ignored. Erase continues. Completed in 00:00:14.343 (Average Transfer Rate: 36553.58 kB/s) PLEASE CHEK AND FAST REPLY |
