02-05-2013, 10:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Htc Desire? Now my set sleep mode. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Desire V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK WARNING: Programming Error (0x24) at 0x000000260000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000270000 is handled as Cut Excess. Resurrection complete! |
02-05-2013, 13:35 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Desire and Nexsus One Needed Full Charged Battrey for Startup,So You Can't Check With Power Supply -- Also: You Can Erase Full Flash Size,Then Resurrect With All Option,Then Check With Battrey And Can you see blinkink LED with Green/orange color..??? |
02-05-2013, 22:40 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Are You Sure About Model? Nexus_One And Desire have a same PCB.... -- Try Erase Full Flash Size,Then Resurrect With All Option And Check Phone Again |
