02-02-2016, 11:39 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2085850 Status: Offline Thanks Meter: 0 | HTC Desire 500 EMMC help Connecting to a dead body ... OK Detected device ID: 0x008E00E1 - RIGHT! Exposed I / O voltage of 2.60V, frequency TCK: RTCK Sampling frequency signal RTCK: [Sample at MAX] Recovery procedure began. Connecting to the device ... OK Initialization of the internal configuration of the device ... OK Loading resurrektora into memory ... OK Installing kommunitsatsii with resurrektorom ... OK Detected and initialized FLASH1 IC, ID: 0x0015 / 0x0100 (K5U00M, 0x0000E9000000 Bytes = 3.64 GB) Detected and initialized FLASH2 IC, ID: 0x0015 / 0x0100 (K5U00M, 0x000000200000 Bytes = 2.00 MB) Flashing a dead body ... ERROR: Timeout waiting for a response from the DCC loader. Trying to recover ... FAIL ERROR: Failed due to multiple errors in the data exchange. Stopped at address 0x000008000200 plugin Louad laout from file, repartition Analizing the FullImage File...ERROR ERROR: Expected signature word 0x55AA, but found different. Cannot continue. Analisis is stopped. So far were found: 39 partitions. Current Phone/Image File has MBR/EBR Structure. Total quantity of listed partitions: 39 ------------------------------ I think need markup memory? tell me what to write in Boot bus config [177] Boot configuration -------------------------------- and what are the analogues memory KMKJS000VM-B309 hope for your help on the current you |
