Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-10-2010, 03:21   #16 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
yessss... the bricked htc desire is now back to live
build a goldcard (can use any other htc, dont need same one like i tought before) and update via sd card using any rom you wish.
thats it!
bootloader after repair is: 0.80.0000
The Following 4 Users Say Thank You to oOXTCOo For This Useful Post:
Old 09-10-2010, 03:30   #17 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
thats it!
kindly post the procedure for reference for the newbies
Old 09-10-2010, 07:50   #18 (permalink)
sources's Avatar
Member: 117604
Thanks Meter: 42
thats it!
what rom you update after repair it
Old 09-10-2010, 09:39   #19 (permalink)
sources's Avatar
Member: 117604
Thanks Meter: 42
HTC Desire repair problem
I try repair it but not ok
What problem her?
Old 09-10-2010, 10:52   #20 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
1.) try to hold power while start connection
2.) check cables for shorts
3.) check cables for correct pinouts
4.) sometimes you need to try some more time to resurrect
5.) RTCK Sample speed set to max (sometimes i set the first box to 4Mhz and it worked)
Old 09-10-2010, 11:02   #21 (permalink)
sources's Avatar
Member: 117604
Thanks Meter: 42
i repair it ok, pro, how to update it back again working. Rom you use to update it?
rom in htc desire before die WWE_2.09.405.8?
Old 09-10-2010, 11:38   #22 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
with a goldcard you can write any rom into it..
i used the latest unbrandet rom available.
1.) make goldcard with your sd card
2.) copy the rom rename it to: PB99IMG.zip
start with back button and power on button pressed, wait a short time and your htc will check the sd card and will start with update...
press vol. up button to say yes to update..
waiting short time... and htc is working again
The Following 2 Users Say Thank You to oOXTCOo For This Useful Post:
Old 09-10-2010, 12:15   #23 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
after you made your goldcard copy this image: RapidShare: 1-CLICK Web hosting - Easy Filehosting
to your sd card.
(dont change the name and dont try to unpack it) just copy it like it is to your sd card.
then all should go well...
Old 09-10-2010, 16:14   #24 (permalink)
sources's Avatar
Member: 117604
Thanks Meter: 42
pro hboot your htc? 0.83 or 0.92 or 0.93
I try update via goldcard and PB99IMG.zip or try
[HOWTO] Downgrade Froyo (2.2) to Stock 2.1 (ANY HBOOT | WIN/LINUX/MAC | ROOT) - xda-developers
My htc sometimes restart or not power on
What problem?
i try update with PB99IMG.zip
[1] radio_v2 fail PU
[2] radio_cust ok
Partion update fail
Radio of your htc?
Old 09-11-2010, 20:01   #25 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
What problem?
[2] radio_cust ok
Partion update fail
Radio of your htc?
http://forum.gsmhosting.com/vbb/6314209-post16.html
Old 09-12-2010, 06:09   #26 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
thats it!
please , can you share here the guide how to get back live after unbrick by RIFFBOX
i have gold card already, firmware or rom please share and simple guide to get it back working again
BIG THANKS
wbr,
Jap
Old 09-13-2010, 07:43   #27 (permalink)
sources's Avatar
Member: 117604
Thanks Meter: 42
Originally Posted by deepakgarg View Post
Hi my friend, i try and not ok. Phone now restart alway after 15 or 10 minutes
Old 09-14-2010, 17:36   #28 (permalink)
Member: 729092
Sonork: 99879
Jtag Desire problem
Tryed for a few times, checked all wires are good, still recieve an error:
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.13, JTAG Manager Version: 1.14
Selected Resurrector: [HTC Desire]
Connecting to the dead body...OK
Detected dead body ID: 0x202400E1 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...FAILED
ERROR: Communication is not established. Terminating.
Any ideas pls?!!
Old 09-14-2010, 19:29   #29 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
hardware fault , and i hope you make all like you read in resurections-help-manual
Old 09-16-2010, 14:24   #30 (permalink)
Sigma's Avatar
Member: 38980
Sonork: 100.84054
Thanks Meter: 124
i have the same problem with desire.
(its working phone, needs unlock.)
is it riffbox hw problem or phone?
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.22617 seconds with 10 queries
