09-10-2010, 03:21 | #16 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | build a goldcard (can use any other htc, dont need same one like i tought before) and update via sd card using any rom you wish. thats it! bootloader after repair is: 0.80.0000 |
The Following 4 Users Say Thank You to oOXTCOo For This Useful Post: |
09-10-2010, 10:52 | #20 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | 1.) try to hold power while start connection 2.) check cables for shorts 3.) check cables for correct pinouts 4.) sometimes you need to try some more time to resurrect 5.) RTCK Sample speed set to max (sometimes i set the first box to 4Mhz and it worked) |
09-10-2010, 11:38 | #22 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | with a goldcard you can write any rom into it.. i used the latest unbrandet rom available. 1.) make goldcard with your sd card 2.) copy the rom rename it to: PB99IMG.zip start with back button and power on button pressed, wait a short time and your htc will check the sd card and will start with update... press vol. up button to say yes to update.. waiting short time... and htc is working again |
09-10-2010, 12:15 | #23 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | after you made your goldcard copy this image: RapidShare: 1-CLICK Web hosting - Easy Filehosting to your sd card. (dont change the name and dont try to unpack it) just copy it like it is to your sd card. then all should go well... |
09-10-2010, 16:14 | #24 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 40
Member: 117604 Status: Offline Thanks Meter: 42 | pro hboot your htc? 0.83 or 0.92 or 0.93 I try update via goldcard and PB99IMG.zip or try [HOWTO] Downgrade Froyo (2.2) to Stock 2.1 (ANY HBOOT | WIN/LINUX/MAC | ROOT) - xda-developers My htc sometimes restart or not power on What problem? i try update with PB99IMG.zip [1] radio_v2 fail PU [2] radio_cust ok . . . Partion update fail Radio of your htc? |
09-11-2010, 20:01 | #25 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
09-12-2010, 06:09 | #26 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Philippines Age: 36
Member: 758106 Status: Offline Sonork: jap_line Thanks Meter: 412 | Quote:
i have gold card already, firmware or rom please share and simple guide to get it back working again BIG THANKS wbr, Jap | |
09-14-2010, 17:36 | #28 (permalink) |
Junior Member Join Date: Mar 2008
Member: 729092 Status: Offline Sonork: 99879 Thanks Meter: 0 | Jtag Desire problem Tryed for a few times, checked all wires are good, still recieve an error: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.13, JTAG Manager Version: 1.14 Selected Resurrector: [HTC Desire] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR: Communication is not established. Terminating. Any ideas pls?!! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
