11-05-2012, 11:20 | #482 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Azerbaijan,Baku Age: 39
Member: 520916 Status: Offline Sonork: 100.1605616 Thanks Meter: 53 | Quote:
for me not solve this again same problem Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip, ID: 0xAAAA/0xAAAA (256MB) Detected a Not Initialized FLASH2 Chip, ID: 0xAAAA/0xAAAA (256MB) ERROR: No Resurrection Data is available for the NAND Chip with Page size = 0B | |
11-27-2012, 13:13 | #483 (permalink) |
Freak Poster Join Date: Jan 2010 Location: romania Age: 33
Member: 1202098 Status: Offline Sonork: none Thanks Meter: 19 | Any ways to repair radio bricked desire? cant install any rom in it... ruu say s image version 2.35.00 hboot is 1.02.0001.. originally it has orang001 cid but with riff we changed to universal 11111111 ... help please. |
12-29-2012, 06:28 | #484 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1859912 Status: Offline Thanks Meter: 0 | Riff-Box 'Tips & 'Tricks Good day, and pleased to meet you -- I see many people here making the same mistake and going rage crazy on thier riff box. **Dont break it! that thing is gold!!!!** I'm so busy in my day to day mobile data device manufacturing / interfacing / programming / integration that I seldom get a chance to post and help people with problems or situations regarding the Joint Test Action Group system of interfacing. First, Riff-box is like a super - duper mega big time advanced adb.exe. Escentially (Not literally) it works by providing you a window to transport information threw. Litterally, threw. I think about myself trying to fit a refrigerator threw a bathroom window. There is only so much I can fit threw a bathroom window. Almost all comments/problems in this thread have to do with people trying to fit a refrigerator threw a bathroom window. RTCK is power up self test type system that regulates all the other signle feeds (ie, TDO, TDI, NRST ect ect) NOT all phones have this option, and this option is the equivelant of easily tossing the refrigerator right threw the bathroom window with no problem. This demands bandwidth, lots of it, being pushed in the form of 100's 0f millions of computations surging threw those tiny serial cable wires, or pogo pins. Just because the Riff Box software is defaulting an option to show a device is RTCK ready, does not mean that it is true. Try turning off RTCK, use a low transfer rate. Remember kh's are MUCH smaller than gh's experiment with the different speeds, you'll learn that every device has a specific "prefered" speed it will operate the most efficiently under. To low of a speed, and it will fail, to fast, same fail. You just have to test and play with it, make a game out of it. When I have problems resurection a phone that includes its own DLL software, I will generally break into a combo of screen play jumps. I start with a resurrect attempt right off the bat, try different speeeds and hope I find something that sticks. If this doesn't work, I'll go to the Jtag read/write pulldown and choose connect and get id. This will usually result in a failure, which is not a big deal. Now, this is a good tip to remember, if the connect and get id, fails, click reset target, if you notice the phone vibrate, change in color indicator patterns, or an obvious boot up, this is a good sign to know your not so much at fault as you think. Refrigerators threw bathroom windows ironically is a delicate proccess. Dont get frustrated if you see the gaping wound red letters making up that horrible word.......... FAIL..... It is a Jtag commonality. You will fail, many times right before succeeding, whithout really changing anything. Jtag and most software works on alot of reverse engineering dialog that the riff box and the computer play out with each other. This is by no means a finite assurance in collegic academics and the process has alot to do with trial and error. Its like the old saying, "Lose a thousand times, oh well. Succeed once, your done." Click connect and get id...... FAIL Click connect and get id..... FAIL FAIL Click copnnect and get id.... you get the message. Bounce around, go to DCC pulldown and try to read allocation units, and after a long mission threw the software underworld, try going back to resurrect and play with more TCK speeds... Remember, dont get mad or curse the box - lack of knowledge and exploration is a big part of this davikish virtual machine we call android. We are all learning - and to learn, you must be wrong first. Another tip to try, is keep RTCK on, but change the TCK speed under it. If nothing more, this will will help learn the ins and outs of the softwares quirks and idioscyncracies. Addressing a few other problems I noticed on this thread -- Red and green blinking light, no charge, still dead after res -- Most likely your resurrect has repartitioned the battery stats to your device. No matter what you do, you will not be able to initially charge a battery with that phone. Best bet is to charge a battery for 24 hours on an alternate device, or external charger. This will give you more time to play with any boot failure issues after resurrect. Make sure you have the Java SDK (Jdk SE), and the proper HTC drivers and adb globals set, these are important. Good luck guys, I probably will not be able to post again for a loooong time. Cheerio. |
05-14-2013, 16:16 | #485 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | Code: [5/14/2013 2:05:28 PM] [START OPERATION_ID = DCC_ERASE_MEMORY] [5/14/2013 2:06:47 PM] Open serial port...OK [5/14/2013 2:06:47 PM] Connecting to the RIFF Box...OK [5/14/2013 2:06:47 PM] Firmware Version: 1.34, JTAG Manager Version: 1.48 [5/14/2013 2:06:47 PM] Selected Resurrector: [HTC Desire V1.00] [5/14/2013 2:06:47 PM] [5/14/2013 2:06:47 PM] Connecting to the dead body...OK [5/14/2013 2:06:47 PM] Detected dead body ID: 0x202400E1 - CORRECT! [5/14/2013 2:06:47 PM] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [5/14/2013 2:06:47 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [5/14/2013 2:06:47 PM] Settings Code: 0x05010000000000000000000020000000 [5/14/2013 2:06:47 PM] [5/14/2013 2:06:47 PM] Resurrection sequence started. [5/14/2013 2:06:47 PM] Establish communication with the phone...OK [5/14/2013 2:06:47 PM] Initializing internal hardware configuration...OK [5/14/2013 2:06:47 PM] Uploading resurrector data into memory...OK [5/14/2013 2:06:47 PM] Starting communication with resurrector...OK [5/14/2013 2:06:47 PM] [5/14/2013 2:06:47 PM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) [5/14/2013 2:06:47 PM] [5/14/2013 2:06:47 PM] Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000001140000. Attempt to Repeat again. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000001140000. Attempt to Repeat again. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000001140000. Attempt to Repeat again. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000001140000. Attempt to Repeat again. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000001140000 is Ignored. Erase continues. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000001300000 is Ignored. Erase continues. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x00000BBC0000 is Ignored. Erase continues. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x00000C180000 is Ignored. Erase continues. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000015720000 is Ignored. Erase continues. [5/14/2013 2:06:47 PM] WARNING: Erasing Error (0x24) at 0x000019620000 is Ignored. Erase continues. [5/14/2013 2:06:47 PM] Completed in 00:01:17.782 (Average Transfer Rate: 6740.48 kB/s) [5/14/2013 2:06:47 PM] [FINISH OPERATION_ID = DCC_ERASE_MEMORY] [5/14/2013 2:07:08 PM] [START OPERATION_ID = RESURRECT] [5/14/2013 2:09:20 PM] Open serial port...OK [5/14/2013 2:09:20 PM] Connecting to the RIFF Box...OK [5/14/2013 2:09:20 PM] Firmware Version: 1.34, JTAG Manager Version: 1.48 [5/14/2013 2:09:20 PM] Selected Resurrector: [HTC Desire V1.00] [5/14/2013 2:09:20 PM] [5/14/2013 2:09:20 PM] Connecting to the dead body...OK [5/14/2013 2:09:20 PM] Detected dead body ID: 0x202400E1 - CORRECT! [5/14/2013 2:09:20 PM] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [5/14/2013 2:09:20 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [5/14/2013 2:09:20 PM] [5/14/2013 2:09:20 PM] Resurrection sequence started. [5/14/2013 2:09:20 PM] Establish communication with the phone...OK [5/14/2013 2:09:20 PM] Initializing internal hardware configuration...OK [5/14/2013 2:09:20 PM] Uploading resurrector data into memory...OK [5/14/2013 2:09:20 PM] Starting communication with resurrector...OK [5/14/2013 2:09:20 PM] [5/14/2013 2:09:20 PM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) [5/14/2013 2:09:20 PM] Selected Resurrection Data for the NAND Chip with Page size = 2KB [5/14/2013 2:09:20 PM] [5/14/2013 2:09:20 PM] Flashing the dead body...OK [5/14/2013 2:09:20 PM] Resurrection complete! [5/14/2013 2:09:20 PM] [FINISH OPERATION_ID = RESURRECT] And it looks that KA1000015M was allready replaced. Phone goes to recovery, but radio timeout when diag is deployed, and with pb99img.zip can't be flashed - it just's hangs on checking pb99img.zip after progress bar came all the way up. any thoughts? New flash ic, or reflow? No charging light whatsoever. Br Haltec |
09-06-2013, 22:02 | #487 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,601 | Quote:
which flash ic did u use for htc desire..? i have the same pb.. and i need to change it.. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
