09-22-2010, 12:14 | #63 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.13, JTAG Manager Version: 1.14 Selected Resurrector: [HTC Desire] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Unlocking the Phone...OK Unlock complete! cables which come with riff is realy bad with own cables - sucesfull unlocked |
The Following User Says Thank You to Boshko_Alfa For This Useful Post: |
09-27-2010, 17:11 | #64 (permalink) |
Freak Poster Join Date: Jul 2005 Location: uk Age: 44
Member: 163725 Status: Offline Thanks Meter: 137 | htc desire unlock? hi guys, i just bought riff box i have to ask can i unlock htc desire? any video how to do it or any pictures? i try to unlock htc desire with jtag (test point) but box is no connecting to phone please need help how to unlock htc desire step by step? thanks very much. |
09-27-2010, 19:36 | #65 (permalink) |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | the best solution is try to use the search button ....there...yepp...upper right side old methode or boot repair but there is some important info's about connection etc http://forum.gsmhosting.com/vbb/f634...-user-1097345/ http://forum.gsmhosting.com/vbb/f634...-riff-1099986/ only unlock: http://forum.gsmhosting.com/vbb/6352258-post43.html regards |
09-28-2010, 05:12 | #66 (permalink) | |
Member: 163725 Status: Offline Thanks Meter: 137 | Quote:
can you please give as pictures what wires did you connect to the phone board did you put usb cable as well? i seen on support it's totally different connections please im stuk on this | |
09-28-2010, 11:16 | #67 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 53
Member: 4611 Status: Offline Thanks Meter: 68 | Just solder the 6 wires that are close together, plug the usb lead in from the computer to the Desire. For the TRST I use one of the "pins" that come with the pack soldered to the TRST wire (makes life easier on the Desire), and hold it on the pad.. No need for gnd (well not for me anyway..the USB from the computer will make this for you). From there, just follow the unlock instructions from the software.. No external power needed, no need for pressing power buttons, no gnd from box, etc.. Just what is written above. |
09-28-2010, 18:15 | #68 (permalink) | |
1st wire its half color one where you put this wire on board? | |
09-28-2010, 18:40 | #69 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Re: [SOLVED] nOOb: How to unlock desire AMOLED with RIFF? Err that's a simple one. I listed all of the wires you need.. that one wasn't mentioned. You simply don't use lead 1. The Guy in the opening of this discussion had done..yes, but it is 100% not connected to unlock a desire. |
09-28-2010, 19:14 | #70 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | my problem is with cables i buy another rainbow ribon cable, not cut not longer than 3/4cm another socket's - and after that all HTC/Samsung phones without problem i conect with Riff. Also use USB from original brand, LG/Samsung/Nokia, use usb2.0 and of corse if u have cheap mainboard - give up from repairing need fast and powerfull config. p.s. i also change pc - and after that don't have problems with riff |
10-02-2010, 20:29 | #71 (permalink) | |
Freak Poster Join Date: Mar 2010
Member: 1263706 Status: Offline Thanks Meter: 31 | Quote:
Hi can you laid down the procedure.As i also don't have working desire to make a gold card but have windows ELF for generating a Gold Card. My question is that can i make a gold card for desire with HTC ELF.IF it is possible then please also little information will solve my issue.I want to flash device to revive back after resurrecting with RIFF.Now it can boot into Fast boot....! Regards, Gsm_Fone. | |
The Following User Says Thank You to Gsm_Fone For This Useful Post: |
10-08-2010, 18:02 | #72 (permalink) |
Member: 1263706 Status: Offline Thanks Meter: 31 | HTC Desire can't enter into bootloader after resurrection. After Creating gold Card and after i ran RUU i got an error.it stuck at 84% ..85%.And error[110] File open error.i re-downloaded files and tried again but always getting same error.Now it is hang at HTC logo and four Triangle are on every corner of LCD. Check the picture below.Now it can't enter into bootloader mode and i tried to repair it via RIFF Jtag but can't enter into bootloader.Just start and hang at HTC logo with triangles.Earlier it was able to enter into bootloader. P.S. Image is copied from this forum.{Thanks to Unknown} earlier it has 0.80 bootloader.I tried repair IMEI Cid ID also. Now it is in the above state. Can any master guide me how to unbrick this Desire...! |
10-13-2010, 05:38 | #73 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 58
Member: 178483 Status: Offline Thanks Meter: 4 | [Answered] how to unlock HTC desire ? RIFF Team please help RIFF Team, can you help me for below question my HTC desire SPL 0.083.00001, can it unlock? by RIFF BOX the unlock is use USB or R45 cable? desire phone is power open or In Fastboot Mode to contact with PC and RIFF BOX for unlock? BR & Thanks |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
