04-20-2013, 08:33 | #2 (permalink) |
Insane Poster Join Date: Aug 2005
Member: 170122 Status: Offline Thanks Meter: 14 | It is working! Log below: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (M00SJS, 0x000091000000 Bytes = 2.27 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (M00SJS, 0x000000100000 Bytes = 1.00 MB) Unlocking the Phone...OK Unlock complete! BR, Florin |
07-17-2013, 07:42 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Can you tell me about exactly your problem? I Have Dump File For Desire_C But Maybe We Can Solve Your Problem Without Dump |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-17-2013, 10:35 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: NCK, Logs, Server
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | Hi, Phone constantly in boot menu. The volume button is checked. By means of RIFF I made super CID and the beginnings flashing process. But when phone has to pass to Download mode, it passes to boot menu. I think Full Flash by JTAG is a last soft chance for this phone WBR! |
09-09-2013, 20:03 | #6 (permalink) | |
Freak Poster Join Date: Dec 2002 Location: Hungary, near Miskolc Age: 48
Member: 19327 Status: Offline Thanks Meter: 45 | Quote:
the story is : i had a working phone for imei change , the new imei is written with riff ,and the phone switched on at first time,but after restart the phone stand in boot loop already I tried to update with RUU , but i can do it in hboot mode and the RUU software says always : the phone's battery less then 30% (of course it is fully charged) . I tried to flash custom recovery with fastboot (to flash custom firmware) but when i select the "recovery" option in the bootloader menu , the phone goes into boot loop again. So i would like to try it the full flash if its possible | |
09-09-2013, 20:51 | #7 (permalink) |
Member: 19327 Status: Offline Thanks Meter: 45 | .. i downloaded from the support torrent,but unfortunately it is password protected Could somebody tell me the correct password for the desire c full flash ? |
09-10-2013, 12:27 | #8 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Guys @ moldovan Can you check This,In H.Boot Menu, Right side of model ,Write "PVT or XA".???? @ clone Yes,All New dump have a PASS We Can't Tell You About PASS But I Can Extract File for You With Remote Please Contact Me Via ICQ Thanks |
