Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 08-09-2012, 10:13   #1 (permalink)
Denva's Avatar
Member: 1274304
Sonork: 100.1617965
HTC Desire cant Uploading resurrector data into memory...FAILED ERROR: RAM memory sel
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.32, JTAG Manager Version: 1.43
Selected Resurrector: [HTC Desire V1.00]
Connecting to the dead body...OK
Detected dead body ID: 0x202400E1 - CORRECT!
Set I/O Voltage reads as 2.99V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
ERROR: RAM memory selftest failed.
What should i do ?
Old 08-09-2012, 10:34   #2 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
Please Read:
RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed.
Please check wire...also only connect usb cable..no need battrey or power supply
Old 08-09-2012, 13:21   #3 (permalink)
Faheem Anjum's Avatar
Member: 399832
what is the status of phone , if you are the user of window xp must try with window 7 some user face problem using xp ,
if you still got same problem then check phone hardware there is no other problem
Old 08-09-2012, 13:25   #4 (permalink)
Denva's Avatar
Member: 1274304
Sonork: 100.1617965
Originally Posted by BABAK NURI View Post
Hi
Please Read:
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB)
Selected Resurrection Data for the NAND Chip with Page size = 2KB
Flashing the dead body...OK
Resurrection complete!
but problem is cant make s-of
Htc one x [Answered] ysr84 Basic Micro-Box Software Support 2 08-10-2012 15:41
E15i cant connect SHIJILFONOTLY RIFFBOX 4 08-09-2012 08:02
since last update cant unlock by testpoint The Repair Shop 4SE 6 08-08-2012 13:49
Htc Diamond100 Malik Irfan85 RIFFBOX 1 08-08-2012 13:45
htc hd2 problem fullpower man HTC & PDA WM( With Touchscreen) 0 08-08-2012 11:16
Page generated in 0.22977 seconds with 11 queries
