09-11-2011, 15:07 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 729092 Status: Offline Sonork: 99879 Thanks Meter: 0 | HTC Desire S no Resurrection Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x001E/0x00C6 (0x0086800000 Bytes) Flashing the dead body... Failed to receive answer to READ command. |
09-20-2011, 10:30 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: On Roads... Age: 43
Member: 107839 Status: Offline Sonork: 100.1592822 Thanks Meter: 70 | Hi, same problem here: Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00CD/0x00A6 (0x0086800000 Bytes) Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000008D200 and it's not soldering problem. pls try to solve it out. B.R |
5110v5.29 no network | GSMlearner | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 04-08-2001 17:15 |
Dejans Flasher Problem with 6150, NO Network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-03-2001 22:39 |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
