09-03-2014, 08:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | HTC Desire SV T326e.... only red light on charging Code: Jtag chain Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC Desire SV (PM8610000) V1.0.4892.63318] Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x007700E1, IR Length = 0x04 bits Total IR length: 0x0004 bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x007700E1: Qualcomm MSM8225, H/W Rev. #0 connect Id .. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC Desire SV (PM8610000) V1.0.4892.63318] Connecting to the dead body...OK Set I/O Voltage reads as 2.58V, TCK Frequency is RTCK Detected dead body ID: 0x007700E1 Resurrection ... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC Desire SV (PM8610000) V1.0.4892.63318] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.58V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x006F (NROM M, 0x000008000000 Bytes = 128.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 131072KB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 03,64GB Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x0000050002 |
