05-19-2014, 17:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Incredıble !ndıa
Member: 113243 Status: Offline Thanks Meter: 77 | htc desire v(pl11100) resurrection ok but cant on i resurrection it all ok but set still dead Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (XINYH, 0x00008F800000 Bytes = 2.24 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (XINYH, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! want to write full dump of 512mb it gives err like this Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x2401000000000000000000008F800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (XINYH, 0x00008F800000 Bytes = 2.24 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (XINYH, 0x000000200000 Bytes = 2.00 MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface ERROR: Main data file size is less than requested to flash to main. pls help me |
05-20-2014, 16:05 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Untick "Autofull" and use "File size" option in data length. And read RIFF FAQ: RIFF JTAG Box FAQ - powered by phpMyFAQ 2.7.9 |
The Following User Says Thank You to legija For This Useful Post: |
