08-26-2013, 21:07 | #1 (permalink) |
Insane Poster Join Date: Aug 2013 Location: west java indonesia Age: 41
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | HTC Desire V still bootloop after resurection Riff BOX [8/26/2013 9:00:56 PM] [START OPERATION_ID = RESURRECT] [8/26/2013 9:01:15 PM] Open serial port...OK [8/26/2013 9:01:15 PM] Connecting to the RIFF Box...OK [8/26/2013 9:01:15 PM] Firmware Version: 1.37, JTAG Manager Version: 1.51 [8/26/2013 9:01:15 PM] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [8/26/2013 9:01:15 PM] [8/26/2013 9:01:15 PM] Connecting to the dead body...OK [8/26/2013 9:01:15 PM] Detected dead body ID: 0x106220E1 - CORRECT! [8/26/2013 9:01:15 PM] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [8/26/2013 9:01:15 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [8/26/2013 9:01:15 PM] [8/26/2013 9:01:15 PM] Resurrection sequence started. [8/26/2013 9:01:15 PM] Establish communication with the phone...OK [8/26/2013 9:01:15 PM] Initializing internal hardware configuration...OK [8/26/2013 9:01:15 PM] Uploading resurrector data into memory...OK [8/26/2013 9:01:15 PM] Starting communication with resurrector...OK [8/26/2013 9:01:15 PM] [8/26/2013 9:01:15 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000091000000 Bytes = 2.27 GB) [8/26/2013 9:01:15 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) [8/26/2013 9:01:15 PM] [8/26/2013 9:01:15 PM] Flashing the dead body...OK [8/26/2013 9:01:15 PM] Resurrection complete! [8/26/2013 9:01:15 PM] [FINISH OPERATION_ID = RESURRECT] Any one have idea, are my HTC have S-off ? the last step i do full dump with file from russian use emmc plugin, but stil not change anything. i try clock from 1 Mhz to max but still not change any think. |
08-27-2013, 16:34 | #3 (permalink) |
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | Last progres, i try use emmc plugin 1. read partition from device 2. try to inject data into partition, i used recovery.img to recovery partition 3. flash recovery partition with succsess 4. but when i try to read recovery partition again, the hex viewer on the right back to first, not change any think. any one to know way this can be happen ? riff box not make change data from emmc, are i have wrong pin out, but jtag read with no eror. |
08-27-2013, 18:46 | #4 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Kz Age: 58
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | You need check 2 things - pm and mcp. And ..... what is phone history before one resurrected? Last edited by Nicolayer; 08-27-2013 at 18:54. |
08-27-2013, 18:57 | #5 (permalink) |
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | i'am sory sir, i'am have bad english and newbie to join forum, what's its pm and mcp ? i have upload my desire v board, that's have diferent board picture from riff box jtag manager, my board like desire x, i confiused with NRST pin out. |
08-28-2013, 18:22 | #6 (permalink) |
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | It is easy, first look here http://forum.gsmhosting.com/vbb/f634...ml#post9686451 Second, pm=power management, mcp=multy chip package=combo flash ram+rom. |
08-31-2013, 02:28 | #7 (permalink) | |
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | Quote:
this board same as picture from jtag manager and this one this board same as my desire V Board and i see a post have riff box log like this : Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - IGNORED! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x20010000000000000000000006000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (XINYH, 0x00008F800000 Bytes = 2.24 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (XINYH, 0x000000200000 Bytes = 2.00 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.031 (Average Transfer Rate: 67650064.48 kB/s) Reading FLASH1 address space from 0x0000004F2200 to 0x0000004F23FF Completed in 00:00:00.016 (Average Transfer Rate: 131071999.94 kB/s) and my desire V riff box log is : [8/31/2013 1:43:32 AM] [START OPERATION_ID = RESURRECT] [8/31/2013 1:43:52 AM] Open serial port...OK [8/31/2013 1:43:52 AM] Connecting to the RIFF Box...OK [8/31/2013 1:43:52 AM] Firmware Version: 1.37, JTAG Manager Version: 1.51 [8/31/2013 1:43:52 AM] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [8/31/2013 1:43:52 AM] Restarting target (nRST Low then High)...OK [8/31/2013 1:43:52 AM] [8/31/2013 1:43:52 AM] Connecting to the dead body...OK [8/31/2013 1:43:52 AM] Detected dead body ID: 0x106220E1 - CORRECT! [8/31/2013 1:43:52 AM] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [8/31/2013 1:43:52 AM] Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] [8/31/2013 1:43:52 AM] [8/31/2013 1:43:52 AM] Resurrection sequence started. [8/31/2013 1:43:52 AM] Establish communication with the phone...OK [8/31/2013 1:43:52 AM] Initializing internal hardware configuration...OK [8/31/2013 1:43:52 AM] Uploading resurrector data into memory...OK [8/31/2013 1:43:52 AM] Starting communication with resurrector...OK [8/31/2013 1:43:52 AM] [8/31/2013 1:43:52 AM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000091000000 Bytes = 2.27 GB) [8/31/2013 1:43:52 AM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) [8/31/2013 1:43:52 AM] [8/31/2013 1:43:52 AM] Flashing the dead body...OK [8/31/2013 1:43:52 AM] Resurrection complete! [8/31/2013 1:43:52 AM] [FINISH OPERATION_ID = RESURRECT] My Question is, are PL1110000.dll resurection can work with my Board type? because Flash chip on both board have diferent size. Thanks advance. | |
08-31-2013, 07:14 | #8 (permalink) |
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | Ofcource riff can work with both type and more. Dont think about riff, should think about loop state, i mean for you should check hw and try use full dump. Last edited by Nicolayer; 08-31-2013 at 07:22. |
The Following User Says Thank You to Nicolayer For This Useful Post: |
08-31-2013, 22:24 | #9 (permalink) | |
1 have try to check hardware, and no problem, hardware it's fine, this phone boot loop after my wife klik update on the phone, when restart, the phone bootloop. i have try to recurection with 1 Mhz RTCK and i right NRST pin, CID 11111111, IMEI rewrite, no error in jtg manager, but still bootloop. i have try direct unlock, and Full erase on Flash1 and Flash2 Chip (with Erase Full Nand/memory Code), no error on jtag manager, but still bootloop. i have try to full read data on DCC, finish with no error. i try again erase full flash, and read on emmc plugin, i got 2,4 Gb data finish with no error, and data it's not empty. perhaps i need HTC klips for unlock, now i try to make a Gold Card from another HTC, result i will be post again. thank's advance for u'r help | |
08-31-2013, 22:35 | #10 (permalink) |
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | i forget to give log when halt 4 time and reset 4 time [01/09/2013 4:30:12] [START OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:12] Open serial port...OK [01/09/2013 4:30:12] Connecting to the RIFF Box...OK [01/09/2013 4:30:12] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:12] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:12] [01/09/2013 4:30:12] Halting target...OK [01/09/2013 4:30:12] STATUS: Target was already halted. [01/09/2013 4:30:12] [01/09/2013 4:30:12] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:12] R1 = 0x50617283 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:12] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:12] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0114 [01/09/2013 4:30:12] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:12] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:12] [FINISH OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:14] [START OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:14] Open serial port...OK [01/09/2013 4:30:14] Connecting to the RIFF Box...OK [01/09/2013 4:30:14] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:14] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:14] [01/09/2013 4:30:14] Halting target...OK [01/09/2013 4:30:14] STATUS: Target was already halted. [01/09/2013 4:30:14] [01/09/2013 4:30:14] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:14] R1 = 0x50617283 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:14] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:14] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0114 [01/09/2013 4:30:14] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:14] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:14] [FINISH OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:16] [START OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:16] Open serial port...OK [01/09/2013 4:30:16] Connecting to the RIFF Box...ERROR [01/09/2013 4:30:16] ERROR: No response from the RIFF Box. [01/09/2013 4:30:16] [FINISH OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:17] [START OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:17] Open serial port...OK [01/09/2013 4:30:17] Connecting to the RIFF Box...ERROR [01/09/2013 4:30:17] ERROR: No response from the RIFF Box. [01/09/2013 4:30:17] [FINISH OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:18] [START OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:18] Open serial port...OK [01/09/2013 4:30:18] Connecting to the RIFF Box...OK [01/09/2013 4:30:18] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:18] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:18] [01/09/2013 4:30:18] Halting target...OK [01/09/2013 4:30:18] STATUS: Target was already halted. [01/09/2013 4:30:18] [01/09/2013 4:30:18] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:18] R1 = 0x50617283 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:18] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:18] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0114 [01/09/2013 4:30:18] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:18] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:18] [FINISH OPERATION_ID = HALT_TARGET] [01/09/2013 4:30:21] [START OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:22] Open serial port...OK [01/09/2013 4:30:22] Connecting to the RIFF Box...OK [01/09/2013 4:30:22] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:22] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:22] [01/09/2013 4:30:22] Resetting target...OK [01/09/2013 4:30:22] STATUS: Target is halted. [01/09/2013 4:30:22] [01/09/2013 4:30:22] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:22] R1 = 0x50617283 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:22] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:22] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0114 [01/09/2013 4:30:22] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:22] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:22] [FINISH OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:26] [START OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:26] Open serial port...OK [01/09/2013 4:30:26] Connecting to the RIFF Box...OK [01/09/2013 4:30:26] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:26] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:26] [01/09/2013 4:30:26] Resetting target...OK [01/09/2013 4:30:26] STATUS: Target is halted. [01/09/2013 4:30:26] [01/09/2013 4:30:26] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:26] R1 = 0x00000000 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:26] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:26] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0118 [01/09/2013 4:30:26] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:26] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:26] [FINISH OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:27] [START OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:27] Open serial port...OK [01/09/2013 4:30:27] Connecting to the RIFF Box...OK [01/09/2013 4:30:27] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:27] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:27] [01/09/2013 4:30:27] Resetting target...OK [01/09/2013 4:30:27] STATUS: Target is halted. [01/09/2013 4:30:27] [01/09/2013 4:30:27] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:27] R1 = 0x50617283 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:27] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:27] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0114 [01/09/2013 4:30:27] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:27] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:27] [FINISH OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:28] [START OPERATION_ID = RESET_TARGET] [01/09/2013 4:30:28] Open serial port...OK [01/09/2013 4:30:28] Connecting to the RIFF Box...OK [01/09/2013 4:30:28] Firmware Version: 1.37, JTAG Manager Version: 1.51 [01/09/2013 4:30:28] Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] [01/09/2013 4:30:28] [01/09/2013 4:30:28] Resetting target...OK [01/09/2013 4:30:28] STATUS: Target is halted. [01/09/2013 4:30:28] [01/09/2013 4:30:28] R0 = 0xB8000824 R6 = 0xF001E64C R12 = 0x55555555 [01/09/2013 4:30:28] R1 = 0x50617283 R7 = 0x02B22540 R13 = 0xF001C370 [01/09/2013 4:30:28] R2 = 0x00122040 R8 = 0xF000C5F0 R14 = 0xF000C5F0 [01/09/2013 4:30:28] R3 = 0x0000000F R9 = 0x00000000 R15 = 0xFFFF0114 [01/09/2013 4:30:28] R4 = 0xFFFFFFE0 R10 = 0x00000000 CPSR = 0x000000D3 [01/09/2013 4:30:28] R5 = 0xF0061610 R11 = 0x00000000 [01/09/2013 4:30:28] [FINISH OPERATION_ID = RESET_TARGET] Sir, on thats log, are have a hardware problem ? |
08-31-2013, 22:59 | #12 (permalink) | |
no, i never try to unlock the phone before bootloop, and phone never have root or CWM, this is my wife phone, she don't care about root/cwm, but she not ask me when press update menu on phone. idon' know the file update on phone it's corrupt or not. thank you very much Mr.babak for reply my post. | |
09-01-2013, 09:37 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Wel come.This is My Job...D: Anyway,It's Important Beause Sometimes We do Prepare Dll From Unlocked Dump... So,After Resurrect You have Unloked phone.... Please Check Again ,if is lock ,leave this step ,if not try relock Then: flash with latest RUU,,,After Done,Power on phone with hold Power down key then select "recovery" and wait for start reovery menu,Then try 2 wipe and reboot (some times need repeat few times for goto recovery,,,Also need push vol up + power key ,same time...for see recovery option) Then,if still not solve.: unlock phone with htcdev flash any compatible CWM install any Custom rom try both wipe also dalvik start fastboot on phone and flash boot.img extracted from custom.zip rom and check phone For all step,,,it can help too "fastboot erase cache or fastboot earse userdata" maybe need "oem" i can't rememeber well thanks |
09-02-2013, 19:24 | #14 (permalink) | |
i beginner on phone service, but i'am is computer technician, before i service my desire, i read any posting about HTC brick case, and the result must be repair with JTAG, And another result The Best JTAG it's Riff Box. So i buy Riff box from riff reseller in my country. i try to update firmware, and i get ver 1.35 and i got second update to ver 1.37 with no problem. I buy Riff just for repair my wife phone. and i want to learn about phone service. I have try go to boot loader and recovery for acsses fastboot, but when phone begin start to restart again (bootloop) i can't go to bootloader used down vol + power buton. and on device manager, usb detect with two HTC disk Drive, no ADB interface or ADB Fastboot. When bootloop phone screen just show loading progres. I Try To search TP on phone board for acsses Qualcom USB Loader, i read all of picture on Jtag Manager who have resurection with USB DCC loader. I Got Miracle, i find that TP for acsses Qualcom USB loader, i used Led on anode(+) to ground and katode(-) to nodle for trry the tp, when light not to on, itry to short to ground with usb computer plug to desire v board, please any one don't do what i do, because i don't now this is right way to search TP on phone and are this TP it's Correct or not, before i short to Gnd, i read voltage on TP using Multitester, i got 1,518 volt and 0,518 volt when i touch that TP. I think it's ok for short to ground. this is my personal TP point for turn on Qualcomm USB Loader. The funny is, when Qualcom USB loader detect in my computer, nothing tools (software) for repair, Riff box not support Desire V USB mode yet. But i got second Mirace, when i plug usb to my desire v board, my hand accidentally short TP to grond for half mili second, i get this on desire v screen fastboot working and can read on cmd, but when i flash boot.img and recovery.img on fastboot, o get mesage sinature not verificated. when i try on recovery, nothing to happen. now i try to resurection or full dump with Riff Box, jtag cable have soldered on desire box, so i plug phone to riff box with bootloader seen on phone screen. | |
