Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 08-22-2013, 11:39   #1 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 139
Htc desire v t328w (pl11100) showing error while resurrection
HTC DESIRE V T328W (PL11100) SHOWING ERROR WHILE RESURRECTION
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.36, JTAG Manager Version: 1.50
Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829]
Connecting to the dead body...OK
Detected dead body ID: 0x106220E1 - CORRECT!
Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...FAILED
ERROR: No response from the RIFF Box.
EXPERTS PLZ HELP ME ......
WAITING FOR GUD REPLY
Regards:-
K@rnv!r
Old 08-22-2013, 11:43   #2 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Hi,
Make sure that NRST and GND pins are connected properly.
After this - try to set up lower RTCK sampling rate, 1MHz for example.
Old 08-22-2013, 11:51   #3 (permalink)
Cheater -Don't Deal with him-
Member: 1850093
Sonork: 100.1627469
Thanks Meter: 339
@kanvir sir please folllow mr legija sir post :P your problem will be solved
Old 08-22-2013, 11:54   #4 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 139
sir i checked again .and .NRST and GND pins are connected properly.
and i also tried to set up lower RTCK sampling rate, but still its showing same error
Old 08-22-2013, 11:56   #5 (permalink)
legija's Avatar
Member: 256342
Sonork: None
If everything is as You said - in that case phone has HW problem.
Old 08-22-2013, 12:02   #6 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 139
sir if its hardware problem then how pc is showing fone's usb drivers ??
Old 08-22-2013, 12:04   #7 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Because for example phone cant detect eMMC chip, and it starts emergency dloader, which is exactly what You have detected on USB.
The Following User Says Thank You to legija For This Useful Post:
Old 08-22-2013, 17:37   #8 (permalink)
Nicolayer's Avatar
Member: 93002
Sonork: 100.1617660
Thanks Meter: 19
Karnvir, hi!
what kind of board have you - A or B? post here how board is labeled.
Old 08-26-2013, 15:50   #9 (permalink)
Member: 2009275
Sonork: 100.1646190
Thanks Meter: 24
i have same problem, but resurection complete, not change any thing to my phone
Old 08-27-2013, 18:23   #10 (permalink)
Member: 2009275
Sonork: 100.1646190
Thanks Meter: 24
Originally Posted by Nicolayer View Post
Karnvir, hi!
what you mind about board A or B, are desire v have two kind of board type ? are the desire v .dll resurection can work with A or B board ?
Old 08-27-2013, 18:40   #11 (permalink)
Nicolayer's Avatar
Member: 93002
Sonork: 100.1617660
Thanks Meter: 19
difference is pad for NRST pin, dll is one for both kinds of board.
Old 08-31-2013, 08:21   #12 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 139
Karnvir, hi!
These are the image of board bro .. i dont know its A or B ...... u check plz....... and tell me if u have any solution of this problem .
thx
Old 08-31-2013, 10:35   #13 (permalink)
Nicolayer's Avatar
Member: 93002
Sonork: 100.1617660
Thanks Meter: 19
well, you have board revision 50H00782-02M_B.
now try 2 things - 1) do "Reset the Target" 2) read some lenght dump from phone memory and post both Logs, RTCK set 2MHz.
Old 08-31-2013, 11:28   #14 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 139
thx for ur reply bro .. i did both of ur advices .. but not got any success .....
well thx again for all of u for ur replies ...
i returned the phone back to customer now
Old 12-30-2013, 11:00   #15 (permalink)
pugazhendhi's Avatar
Member: 141927
Thanks Meter: 27
HTC Desire V T328w Error
Firmware Version: 1.37, JTAG Manager Version: 1.54
Detected dead body ID: 0x000000E1 - WRONG!!!
ERROR: Current ID does not belong to the HTC DesireV (PL1110000) family.
AFTER TICK Ignore Target IDCODE
Detected dead body ID: 0x000000E1 - IGNORED!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz]
Establish communication with the phone...FAILED
ERROR(0x44): Communication is not established. Terminating.
Page generated in 0.29096 seconds with 9 queries
