08-22-2013, 11:39 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: ÞÚÑJÁß Age: 34
Member: 741065 Status: Offline Thanks Meter: 139 | Htc desire v t328w (pl11100) showing error while resurrection Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. EXPERTS PLZ HELP ME ...... WAITING FOR GUD REPLY Regards:- K@rnv!r |
08-22-2013, 11:54 | #4 (permalink) |
Member: 741065 Status: Offline Thanks Meter: 139 | sir i checked again .and .NRST and GND pins are connected properly. and i also tried to set up lower RTCK sampling rate, but still its showing same error |
08-22-2013, 12:04 | #7 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Because for example phone cant detect eMMC chip, and it starts emergency dloader, which is exactly what You have detected on USB. |
The Following User Says Thank You to legija For This Useful Post: |
08-31-2013, 10:35 | #13 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Kz Age: 58
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | well, you have board revision 50H00782-02M_B. now try 2 things - 1) do "Reset the Target" 2) read some lenght dump from phone memory and post both Logs, RTCK set 2MHz. |
08-31-2013, 11:28 | #14 (permalink) | |
Member: 741065 Status: Offline Thanks Meter: 139 | Quote:
well thx again for all of u for ur replies ... i returned the phone back to customer now | |
12-30-2013, 11:00 | #15 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 141927 Status: Offline Thanks Meter: 27 | HTC Desire V T328w Error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x000000E1 - WRONG!!! ERROR: Current ID does not belong to the HTC DesireV (PL1110000) family. AFTER TICK Ignore Target IDCODE Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x000000E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. |
