10-21-2013, 13:35 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: chittorgarh (Raj.) INDIA
Member: 363265 Status: Offline Sonork: 100.1648064 Thanks Meter: 65 | Htc desire v t328w Resurrection error Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x646F (M MORN, 0x000008000000 Bytes = 128.00 MB) ERROR: Read Failed with Error Code: 0x46. Terminating at 0x000002E73800 Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000005000200 stuck on 2%... plz help what should i do... how can i solve this problem need help urjent |
10-21-2013, 19:57 | #4 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Viet nam
Member: 231600 Status: Offline Thanks Meter: 44 | i repair ok.May be your phone is HW! Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (XINYH, 0x00008F800000 Bytes = 2.24 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (XINYH, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! |
10-22-2013, 05:49 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi mobilecare 786 This is your problem : Quote:
128mb : is not real size too So,Replace eMMC as Nikolayer told you befor | |
08-13-2014, 18:14 | #7 (permalink) |
Freak Poster Join Date: Jul 2008 Location: india
Member: 816244 Status: Offline Sonork: 100.1626537 Thanks Meter: 91 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! WARNING: Embedded I/O Voltage is overriden to 3.05V Set I/O Voltage reads as 3.07V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (XINYH, 0x00008F800000 Bytes = 2.24 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (XINYH, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! resurrection complete but phone same condition ! no boot mode no usb detection! |
10-17-2014, 10:10 | #8 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2069837 Status: Offline Thanks Meter: 17 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x000000E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. Help mee |
12-07-2014, 13:55 | #9 (permalink) |
Insane Poster Join Date: Jan 2013
Member: 1871927 Status: Offline Thanks Meter: 3 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.48 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x646F (M MORN, 0x000008000000 Bytes = 128.00 MB) ERROR: Read Failed with Error Code: 0x46. Terminating at 0x000002E73800 Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000005000200 hep what i can |
01-13-2015, 08:18 | #10 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 24 | htc desire v Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x646F (M MORN, 0x000008000000 Bytes = 128.00 MB) ERROR: Read Failed with Error Code: 0x46. Terminating at 0x000002E73800 Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000005000200 |
