08-06-2012, 09:58 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | HTC desire z Resurrection problem Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [HTC Desire Z V1.0.4498.3661] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
08-06-2012, 20:51 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Read: RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed. ----------------- You Need Check or Try : 1-Solder wires 2-set speed at low 3-Use Usb dll Version 4-Connect power supply or Battery...Also Usb-Cable ---- Can You Tell Me About Phone History...? |
11-01-2012, 12:55 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You can use any dll based on MSM8255 for any other phone based too for Read\Write But What happen if you try "Resurrect" Vision With Vivo.dll....? Desire-Z(Vision) Have a "PC1010000 as Model ID ...Also "(0.76.2000 or 0.85.0005)" Sbl Incredible-S(Vivo) Have a "‘PG3213000’ as Model ID....Also "(1.13.0000)" SBL --- So,You Can't Resurrect,Because You can't flash with RUU.exe |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
