08-13-2010, 15:20 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | * * * HTC Dream - Google G1 RIFF JTAG Mega thread ! * * * Open serial port...OK Connecting to the RIFF Box...OK Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data length received. |
08-13-2010, 16:27 | #3 (permalink) | |
Member: 88402 Status: Offline Thanks Meter: 489 | HTC g1 problem solved Quote:
THANK YOU. Open serial port...OK Connecting to the RIFF Box...OK Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00AD/0x55BA Flashing the dead body...OK Resurrection complete! | |
08-15-2010, 17:54 | #5 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1196226 Status: Offline Thanks Meter: 0 | Problem with G1 jtag What should I do with this error? Open serial port...OK Connecting to the RIFF Box...OK Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0xAAAA/0xAAAA ERROR: Selected FLASH Chip was not initialized by the DCC Loader. Please help me. |
08-15-2010, 18:31 | #6 (permalink) |
Member: 1196226 Status: Offline Thanks Meter: 0 | Or some time error is like this: Open serial port...OK Connecting to the RIFF Box...OK Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Failed finalization step one. Terminating. Now what should I do? |
08-20-2010, 16:24 | #7 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | HTC G1 unlock with RIFF - how to ? i guy. i have one HTC G1 to unlock. it's working but locked. how to unlock it with RIFFBOX ? 10x |
The Following User Says Thank You to Svetli For This Useful Post: |
08-20-2010, 18:29 | #8 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | easy make resurector and soft will you ask imei change? you make yes and write your imei from this phone (original imei ) and resurections button and your phone is unlocked and you have your original imei . |
The Following 3 Users Say Thank You to sen-i For This Useful Post: |
08-24-2010, 19:10 | #14 (permalink) |
Major Poster Join Date: Jul 2010
Member: 1351184 Status: Offline Thanks Meter: 2 | Alternative Pinout nrst G1? [COLOR=White]Alternative Pinout nrst G1? Mr Legija I have a problem with a Htc g1 Nsrt pinout came off and not have , there an alternative ? [IMG=http://img827.imageshack.us/img827/3716/nrts.png][/IMG] Uploaded with ImageShack.us Uploaded with ImageShack.us |
08-24-2010, 20:05 | #15 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 1. Switch to JTAG TAB 2. Click "Connect&Get ID" 3. Power off the pcb 4. Click "Reset the Target" 5. Quickly repower phone PCB - if result ok then, (If not, repeat the steps from step 3) 6 Switch to "Resurrection" TAB 7. Click "Do the magic" button. |
Mega offer : for all nokia lovers ;-) | 666 | Main Sales Section | 1 | 02-01-2002 02:35 |
SMS Prank, thread ??? | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-09-2002 11:38 |
Mega-Guru! Help! 5110 is dead! | ReBoot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-19-2001 21:24 |
