04-15-2014, 11:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2014
Member: 2136780 Status: Offline Thanks Meter: 68 | HTC ELF problem repair boot i have htc ELF is dead and can not repair boot how sloved problem Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Elf V1.00] Connecting to the dead body...OK Detected dead body ID: 0x0692602F - CORRECT! Set I/O Voltage reads as 3.28V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
04-17-2014, 01:12 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Of course not good,Because i see many gust ID Please check Connection and Read Carefully Resurrection Manual Thanks |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
04-19-2014, 15:49 | #4 (permalink) | |
Member: 2136780 Status: Offline Thanks Meter: 68 | Quote:
check connection and is good wires I checked several times and resolder the connections wires but again write error Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. | |
