02-25-2012, 16:35 | #1 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1726428 Status: Offline Thanks Meter: 0 | HTC Glacier/My touch 4G help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Glacier] Connecting to the dead body...ERROR ERROR: The RTCK Signal does not respond. What should i do. everything is solder correctly |
02-26-2012, 00:14 | #3 (permalink) |
Member: 1726428 Status: Offline Thanks Meter: 0 | Ok, I have 3 HTC Glacier two of them i try repairing the IMEI and after i Resurrect the board the phone does not turn on and one of them i did the Resurrection and still in the start up logo....Please help me on this. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Glacier] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x008B000000 Bytes) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x0000100000 Bytes) Flashing the dead body...OK Resurrection complete! |
03-03-2012, 16:06 | #9 (permalink) |
Member: 1726428 Status: Offline Thanks Meter: 0 | Ok, the other two I wanted to unlock it and after i did the process i got the following log and after the process the phones do not turn on. but the funny part is if i do the process again it goes tru but still no power..... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.40 Selected Resurrector: [HTC Glacier V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x00008B000000 Bytes = 2.17 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Unlocking the Phone...OK Unlock complete! |
03-04-2012, 01:36 | #10 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | have u tested the power button of the two phones before IMEI repair. if possible, try phone with power supply and check if phone consume current when holding power on button. if not then u must check power button since this is a known problem with HTC Glacier and others (Desire, Nexus One...). |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
03-05-2012, 15:44 | #11 (permalink) |
Member: 1726428 Status: Offline Thanks Meter: 0 | Yup I try the power botton flex on another phone and it turns on but on this one it doesn't....The funny thing is if i do the process againg of the repair IMEI it does it and it says done but no power.... |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
