08-05-2011, 02:28 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: COLOMBIAA
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | HTC HD dead no cant repair i have htc hd radio damage no turn radio then i repair with riff but show this error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.34 Selected Resurrector: [HTC HD] Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. THEN now this phone is dead dead my customer is angry b,r |
08-05-2011, 14:17 | #4 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | Most common errors: v The NRST signal is not connected. Please ALWAYS SOLDER THE NRST SIGNAL whenever it is present on the schematics. In case you have JIG please make sure NRST is routed, if not - solder wire manually. v Connection is unstable or cannot be established at all. Please make sure JTAG wires are of the SAME LENGTH and not exceed ~10..15 cm in length; make sure RTCK is selected; compensate signals propagation errors by adjusting the RTCK Sampling Frequency; for better stability, avoid using fixed TCK frequency. BR |
08-08-2011, 07:25 | #6 (permalink) | |
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | Quote:
thanks for the help NRST pinout resolder the good and all íns and shows me the same error as I do?? how can repair imm going crazyyyy ;(_ SUPPORT RIFF ???? thxs b,r | |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
cant unlock CSI eeprom | Stryker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-20-2000 13:00 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
