02-20-2013, 10:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | HTC inspire 4g error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Inspire V1.00] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - WRONG!!! ERROR: Current ID does not belong to the HTC Inspire family. B:R Last edited by leventc; 02-20-2013 at 10:26. |
03-04-2013, 12:46 | #5 (permalink) |
Junior Member Join Date: Aug 2007
Member: 560132 Status: Offline Thanks Meter: 0 | Have the same phone, if you disable the scan of id the procedure of restoration проходит. but the phone is not включается. after you press the power button 7 вибраций. is there a solution you have? |
03-04-2013, 12:49 | #6 (permalink) |
Member: 560132 Status: Offline Thanks Meter: 0 | Have the same phone, if you disable the scan of id the procedure of restoration done and exits. but the phone is not включается. after you press the power button 7 вибраций. is there a solution you have? |
03-04-2013, 13:00 | #7 (permalink) |
Member: 560132 Status: Offline Thanks Meter: 0 | Have the same phone, if you disable the scan of id the procedure of restoration goes. but the phone is not turned on. after you press the power button 7 vibrations. is there a solution you have? |
03-05-2013, 01:32 | #8 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
7 Times Vibration is Mean Damaged eMMC Chip(99.9%) So,Please Try it | |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
05-14-2013, 11:29 | #10 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 49
Member: 159411 Status: Offline Thanks Meter: 8 | Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - WRONG!!! ERROR: Current ID does not belong to the HTC Inspire family. ı have the same problem. bypas id check nothing help me. if you have solution please can you write here BABAK NURİ |
05-14-2013, 12:45 | #11 (permalink) | |
Please Post Full Log With Disable/Ignore ID Code... | |
