01-15-2013, 15:50 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | HTC Jetsream 4g LTE At&t boot faulty dont supported now |
01-15-2013, 16:15 | #2 (permalink) |
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | [IMG] Uploaded with ImageShack.us[/IMG] |
01-16-2013, 07:01 | #4 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1501506 Status: Offline Thanks Meter: 47 | JTAG diagnostic port is clearly visible in the last photo you uploaded. Probe to determine which pin is ground, then use standard HTC pinout which is typically used. You can use the Flyer pinout picture within RIFF for reference to what each pin will be. Contact Legija or Babak after doing so and connecting the device. Use Sensation 4G dll and analyze the chain to make sure you get the proper APQ8060 ID. |
The Following 2 Users Say Thank You to connexion2005 For This Useful Post: |
01-16-2013, 12:26 | #5 (permalink) |
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | have conections like evo3d Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC EVO3D (PG8630000) V1.0.4562.63032] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x05010000000000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MBG8FA, 0x000774000000 Bytes = 29.81 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MBG8FA, 0x000000080000 Bytes = 0.50 MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Reading FLASH1 address space from 0x000000000000 to 0x000773FFFFFF |
01-17-2013, 07:30 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Contact Mr.Legija At Sonork Or Me... Thanks |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
