11-04-2013, 17:48 | #1 (permalink) |
Insane Poster Join Date: Dec 2006 Location: Toplita Romana
Member: 419497 Status: Offline Sonork: 100.1615725 Thanks Meter: 5 | HTC One M7 resurrection ERROR When connect the phone with usb this show it Qualcomm HS-USB QDLoader 9008. I tried everything nothing works. Please help me! Thanks in advance! Here is my log: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneM7 (PN0710000) V1.0.4926.46931] Connecting to the dead body...OK Detected dead body ID:ID: 0x207150E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: No response from the RIFF Box. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneM7 (PN0710000) V1.0.4926.46931] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x04 bits Device on TAP #1: ID = 0x207150E1, IR Length = 0x0B bits Total IR length: 0x000F bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x4BA00477: Generic CORTEX-A9/A15 Core Based Target 2. 0x207150E1: Qualcomm MSM8930, H/W Rev. #2 Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneM7 (PN0710000) V1.0.4926.46931] Getting EmbeddedICE-RT registers...OK 00 = 0x00000000 08 = 0x00000000 10 = 0x00000000 01 = 0x0000000C 09 = 0x00000000 11 = 0x00000000 02 = 0x00000000 0A = 0x00000000 12 = 0x00000000 03 = 0x00000000 0B = 0xFFFFFFFF 13 = 0xFFFFFFFF 04 = 0x70000000 0C = 0x00000000 14 = 0x00000000 05 = 0x00000000 0D = 0x000000F7 15 = 0x000000F7 06 = 0x00000000 0E = 0x00000000 16 = 0x00000000 07 = 0x00000000 0F = 0x00000000 17 = 0x00000000 |
11-05-2013, 12:30 | #4 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Usually all users think they soldered wires perfectly, and then think something wrong with RIFF. In 99% cases such problems come from user's imperfection. GND or NRST lines have bad connection. |
The Following User Says Thank You to legija For This Useful Post: |
11-05-2013, 15:54 | #5 (permalink) |
Member: 419497 Status: Offline Sonork: 100.1615725 Thanks Meter: 5 | I checked all connections and solder again but without success. This phone dead after s-off flashing. This is first HTC ONE phone with EMMC SK Hynix H26M64003DQR, other phone that i repaired came with EMMC Samsung. Maybe this is the problem...I try to resurrect with HTC Droid DNA (PL8320000).dll after i read about this in other forum. This is my result: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Droid DNA (PL8320000) V1.0.4926.47214] Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035 ERROR: Selected FLASH1 Chip was not Recognized by the DCC Loader. Terminating. Thanks for help Mr. legija . |
11-06-2013, 16:27 | #6 (permalink) |
Freak Poster Join Date: Nov 2011 Location: IRAN Age: 39
Member: 1691551 Status: Offline Sonork: 100.1622582 Thanks Meter: 53 | this log but phone not ok? mr legija ? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneM7 U (PN0711000) V1.0.5046.47163] Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HBG4E, 0x000748000000 Bytes = 29.13 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HBG4E, 0x000000400000 Bytes = 4.00 MB) Flashing the dead body...OK Resurrection complete! |
11-09-2013, 15:42 | #7 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Hello Same problem here...dead fukng Htc one..only Qhsusbl... Resurrect error.... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [HTC OneM7 (PN0710000) V1.0.4926.46931] Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Sometime have this error... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [HTC OneM7 (PN0710000) V1.0.4926.46931] Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x07080036 ERROR: Selected FLASH1 Chip was not Recognized by the DCC Loader. Terminating. No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 29.12GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. All connection are good...any help ? |
11-16-2013, 17:35 | #8 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2064213 Status: Offline Thanks Meter: 1 | have HTC One M7 the problem is not turning on and not charging either, it did try to turn on once when it was plugged in to my PC but screen showed up for brief moment and vibrated but disappeared after that. When I plug the phone to PC it is trying to load the driver and also show up as USN input in device manager and also PC making noise same as when we plug and unplugging USB continuous I tried to hold volume + power and PC making noise like something detecting but nothing showing up in my computer. After playing around enough with hardware buttons now RED LED starting flashing. I really appreciate if someone can help me to narrow down the problem. Thanks Sent from my SGH-I337M using Tapatalk |
