04-12-2014, 16:01 | #1 (permalink) |
Major Poster Join Date: May 2011 Location: Russia,Chechen republic,Grozny Age: 41
Member: 1580337 Status: Offline Thanks Meter: 6 | HTC One Mini (PO5820000) Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneMini (PO5820000) V1.0.5165.44619] Connecting to the dead body...OK Detected dead body ID: 0x2072D0E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 2 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HAG4D, 0x0003AB800000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HAG4D, 0x000000400000 Bytes = 4.00 MB) ERROR: Read Failed with Error Code: 0x28. Terminating at 0x000007FFC000 Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneMini (PO5820000) V1.0.5165.44619] Connecting to the dead body...OK Detected dead body ID: 0x2072D0E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 2 MHz Settings Code: 0x040207000000000000000003AB800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HAG4D, 0x0003AB800000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HAG4D, 0x000000400000 Bytes = 4.00 MB) Erasing FLASH2 memory from 0x000000000000 to 0x0000003FFFFF...OK Completed in 00:00:00.094 (Average Transfer Rate: 43574.47 kB/s) |
