12-02-2013, 12:20 | #1 (permalink) |
Junior Member Join Date: Aug 2008
Member: 828089 Status: Offline Thanks Meter: 7 | htc one s after boot reapair still dead I got a htc one s pj40100 dead. when connect to pc for a moment showing device but immediately disconnected and in device manager refreshing ( connect disconnect ). I repaired its boot by riff box ver 1.55 . now phone is dead and when connect it to pc show device not recognized. this is the log what is the solution??? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407950E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0100 (SEM16G, 0x0003B5400000 Bytes = 14.83 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0100 (SEM16G, 0x000000400000 Bytes = 4.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 14.83GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.56GB Flashing the dead body...OK Resurrection complete! |
12-04-2013, 21:48 | #3 (permalink) |
Member: 828089 Status: Offline Thanks Meter: 7 | RIFF BOX supporters if there is no way to repair this phone let me know to assemble phone and return it to owner. i also try to write full dump from support ( htc one s4 jet) it is about 5 gb and show size error. tray to dump from phone and it look like try to dump 16 gb about 50 hrs . also try with full options Resurrection but same result and usb device not recognized. |
