02-17-2014, 18:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: philippines
Member: 49854 Status: Offline Sonork: 100.1652592 Thanks Meter: 38 | HTC One S PJ40110 still not booting Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Custom Target: [SNAPDRAGON S4 ARM7TDMI, 1.80V, TAP0] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x04 bits Device on TAP #1: ID = 0x407910E1, IR Length = 0x0B bits Total IR length: 0x000F bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x4BA00477: Generic CORTEX-A9/A15 Core Based Target 2. 0x407910E1: Qualcomm MSM8260A, H/W Rev. #4 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.56GB Flashing the dead body...OK Resurrection complete! still not entering bootloader 2nd tried flashing from support one s 4g by jet file Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x280100090000000000000000A3DFFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Resuming write FLASH1 memory from 0x000000000000 to 0x0000A3DFFFFF on 0x000025340000 Completed in 06:21:41.032 (Average Transfer Rate: 117.24 kB/s) phone is still not booting only detected as Qualcomm HS-USB QDLoader 9008 is the full dump in the support PJ40100 or PJ40110? |
