04-09-2015, 07:44 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Pakistan
Member: 628369 Status: Offline Sonork: 100.1609794 Thanks Meter: 48 | HTC One S Stuck on Qualcomm HS-USB after write bin file [4/8/2015 9:03:53 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [4/8/2015 9:03:53 PM] [4/8/2015 9:03:53 PM] Current Settings: [4/8/2015 9:03:53 PM] ----------------- [4/8/2015 9:03:53 PM] Address: 000000000000 [4/8/2015 9:03:53 PM] Length: 000100000000 [4/8/2015 9:03:53 PM] Address Space: ROM1 [4/8/2015 9:03:53 PM] AutoFullFlash: UNCHECKED [4/8/2015 9:03:53 PM] Use End Address: UNCHECKED [4/8/2015 9:03:53 PM] ECC Module Enabled: UNCHECKED [4/8/2015 9:03:53 PM] Image File is Used: UNCHECKED [4/8/2015 9:03:53 PM] Use Address as Offset: UNCHECKED [4/8/2015 9:03:53 PM] Main (CHECKED): E:\Movies\HTC\HTC One S4\one s live_.bin [4/8/2015 9:03:53 PM] Redu (UNCHECKED): [4/8/2015 9:03:53 PM] [4/9/2015 4:43:37 AM] Open serial port...OK [4/9/2015 4:43:37 AM] Connecting to the RIFF Box...OK [4/9/2015 4:43:37 AM] Firmware Version: 1.37, JTAG Manager Version: 1.56 [4/9/2015 4:43:37 AM] Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] [4/9/2015 4:43:37 AM] [4/9/2015 4:43:37 AM] Connecting to the dead body...OK [4/9/2015 4:43:37 AM] Detected dead body ID: 0x407950E1 - CORRECT! [4/9/2015 4:43:37 AM] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [4/9/2015 4:43:37 AM] Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] [4/9/2015 4:43:37 AM] Settings Code: 0x2001000A000000000000000100000000 [4/9/2015 4:43:37 AM] [4/9/2015 4:43:37 AM] Resurrection sequence started. [4/9/2015 4:43:37 AM] Establish communication with the phone...OK [4/9/2015 4:43:37 AM] Initializing internal hardware configuration...OK [4/9/2015 4:43:37 AM] Uploading resurrector data into memory...OK [4/9/2015 4:43:37 AM] Starting communication with resurrector...OK [4/9/2015 4:43:37 AM] [4/9/2015 4:43:37 AM] Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0100 (SEM16G, 0x0003B5400000 Bytes = 14.83 GB) [4/9/2015 4:43:37 AM] Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0100 (SEM16G, 0x000000400000 Bytes = 4.00 MB) [4/9/2015 4:43:37 AM] [4/9/2015 4:43:37 AM] Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED [4/9/2015 4:43:37 AM] The DCCLoader USB Interface is not found. Communication continues over the DCC Interface [4/9/2015 4:43:37 AM] [4/9/2015 4:43:37 AM] Resuming write FLASH1 memory from 0x000000000000 to 0x0000FFFFFFFF on 0x0000304E0000 [4/9/2015 4:43:37 AM] Completed in 07:39:32.911 (Average Transfer Rate: 152.12 kB/s) [4/9/2015 4:43:37 AM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] |
