06-10-2014, 07:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: 90-region Age: 39
Member: 1246378 Status: Offline Thanks Meter: 123 | htc one sv pl80100 Resurrection .FAILED help team Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Package: [HTC OneSV (PL801000) V1.03 by <legija>] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x207230E1 Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. image Last edited by ganjbek; 06-10-2014 at 07:44. |
06-10-2014, 08:23 | #2 (permalink) | |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Quote:
JTAG TCK Speed =RTCK =sample at 12 MHz use this setting and try again Adjust RTCK/TCK sampling to lower value Recheck connection | |
06-10-2014, 16:05 | #3 (permalink) |
Freak Poster Join Date: Jun 2003 Location: New York
Member: 31012 Status: Offline Thanks Meter: 6 | You have to set the TCK speed to 6Mhz or other, not the RTCK Sample speed. I am using TCK 6mhz, connection no problem. But Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (M8G2FB, 0x0001D2000000 Bytes = 7.28 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (M8G2FB, 0x000000200000 Bytes = 2.00 MB) Resurrector Job is Finished. I am still waiting for Legija and team to me solutions. |
06-10-2014, 22:52 | #4 (permalink) | |
Freak Poster Join Date: Apr 2012 Location: Iran
Member: 1748375 Status: Offline Sonork: 100.1617845 Thanks Meter: 17 | Quote:
06-12-2014, 13:00 | #8 (permalink) | |
Member: 1246378 Status: Offline Thanks Meter: 123 | Quote: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Package: [HTC OneSV (PL801000) V1.03 by <legija>] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x207230E1 Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x84 | |
06-13-2014, 09:09 | #9 (permalink) | |
you have any thoughts about it sorry bad english | |
06-13-2014, 14:54 | #10 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | Same problem to me..... I downloded.. AGAIN.. this pack from leija forum... replace old pack, restart riff soft... but same error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Package: [HTC OneSV (PL801000) V1.03 by <legija>] Connecting to the dead body...OK Detected dead body ID: 0x207230E1 Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x84 br Mihnea |
08-28-2015, 15:26 | #14 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Quote:
