08-21-2013, 05:55 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | HTC one v bricked ---- Moderators pls help Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector... i read a post by Mr. legiga that i this case i need DCCUSB loader driver . pls tell me where can i get this . urgently waiting for ur reply . regards suraj |
08-21-2013, 07:00 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Need Use TP...Then Need Install Driver From RIFF Direcctory -- One-v Usually Detect By PC Without TP but You Must Use TP |
08-21-2013, 08:03 | #4 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | Babak sir , legiga sir , Moyal sir ---- respected sir , my phone when is making com port if i insert usb cable . Do i still need to do TP , because i read somewhere in legiga's post that doing TP is risky . pls experts guide me. regards suraj |
08-21-2013, 10:16 | #5 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000092400000 Bytes = 2.29 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Terminating at 0x00000008D200 after following all the procedures i am getting this error. pls respond |
