12-04-2012, 03:47 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please write english.... --- So.You need use TP,if you did,you need repeat again until correct detect Also,if you want only imei repair,Please select only imei option and deselect all other |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
12-04-2012, 22:01 | #3 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: М.o.s.c.o.w.
Member: 649775 Status: Offline Thanks Meter: 242 | Quote:
the problem is that when I try to repair imei stays loading as seen in the photo the testpoint is the same point of riifbox recognizes the Qualcomm HS-USB drivers QDLoader any help please ??? | |
12-05-2012, 02:13 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Just Follow This; 1-disassemble phone 2-Connect usb cable only to phone 3-connect TP 4-Put USB to PC 5-After 3 sec Release TP 6-Press "Resurrect" ---- Maybe You need some try |
