Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 07-17-2013, 10:32   #1 (permalink)
Member: 938032
HTC One V (PK76110) Dead after read unlock codes by other box now is bricked
Hello i have this device that was working well but i tried to read unlock codes by micro sd card method by other box all procedure was ok but when it finished i tried to power on the device and it become dead when i connect to pc its detected as Zeus flash device, i repeat phone was just ok i just read the unkock codes, i tried to put in HS-USB QDLoader mode but i make the tp to make the resurrection with riff box and nothing happens only detected as zeus flash device again and again :s is this device really totally bricked or there is some way to maki it alive again? please help me
pd here is the logs from read unlock code procedure if it helps in some way
sorry my poor english
Connecting with One V
To connect with this phone you should use special microSD cable.
Press the button "Cable" to view pinout.
In order to make microSD cable you should do the following:
1. Get microSD card (1Gb or 2Gb, don't use SDHC).
2. Get two thin wires.
3. Solder first wire to microSD to pin4(+2.8V..+3.3V).
4. Solder second wire to microSD to pin6(GND).
5. You can use any +3V source (even 2xAAA) as power supply.
6. Also you should use microSD card reader.
7. External power supply(+3V) needed only for the phone microSD reader.
8. Do not use external power supply with PC microSD reader.
WARNING: Don't forget to click "Disconnect" at the end.
Connected
Don't forget to post success story on official xxxxxx forum.
Disconnected
Connected
Receiving phone info
In order to connect with phone you should:
1. Install HTC ADB drivers
2. Turn on the phone
3. Enable Debug mode in phone (Settings->Applications->USB Debug)
4. Check your Internet connection
5. Plug USB Cable
Probing ADB Interface...
Android Debug Bridge version 1.0.29
Starting ADB server...
Waiting for device...
Device Found: HT242TV15600
Waiting for data...
Waiting for boot completion...
Waiting for device id...
Getting data...
Serial Number: HT242TV15600
Android Version: 4.0.3
Manufacturer: HTC
Model: HTC ONE V
Hardware: primou
ROM Version: 1.60.516.4
BOOT Version: 1.16.0000
IMEI: 351817-05-019921-7
CID: BSTAR301 / Brightstar-SPA
Backup CID: BSTAR301
Linux Kernel Version: 3.0.16-gf9ce235
Removing Root Privileges...
Stopping ADB server...
Info received
Reading codes
Searching microSD disk...
MicroSD disk found:
Volume: F:\
Device: \\.\PhysicalDrive2
Label: BLACKBERRY2
Writing image to microSD disk...
Writing image to microSD disk: OK
Waiting for User's Actions...
MicroSD disk found:
Volume: F:\
Label: HTCTOOL
Reading codes...
Connecting to server...
Sending data to server...
Receiving data from server...
Unlock codes:
NCK: 34382125
NSCK: NONE
SPCK: NONE
CPCK: NONE
SIMCK: NONE
Read codes success
Disconnected
Old 07-17-2013, 10:48   #2 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
You wont like it, but eMMC is killed now. +3V point on SD card reader was probably supplied with much higher voltage.
You'll have to replace it.
How ironic this part sounds now:
The Following User Says Thank You to legija For This Useful Post:
Old 07-17-2013, 11:01   #3 (permalink)
Member: 938032
to bad to know that, anyway thanks for your reply boss
Page generated in 0.11830 seconds with 8 queries
