10-14-2013, 13:18 | #1 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1964367 Status: Offline Thanks Meter: 2 | HTC ONE V (primou) riffbox only hboot First of all i created fullflash image by DCC Read/Write (the phone was workable) Then I checked all except IMEI field In the resurrection menu ----------------------------------------------------- Open serial port OK Connecting to the RIFF Box OK Firmware Version: 1 37, JTAG Manager Version: 1 54 Selected Resurrector: [HTC OneV (PK76100) via USB V1 0 4608 58885] Looking for the HS-USB QDLoader Interface OK Open the HS-USB QDLoader Interface Port OK Establish connection with the Device OK Uploading resurrector data into memory OK Starting communication with resurrector OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (M4G1FB, 0x000091000000 Bytes = 2 27 GB) Flashing the dead body OK Resurrection complete! ------------------------------------------------------------------- After that i got a brick I can open only HBOOT *** LOCKED *** PRIMOU XA SHIP S-ON RL HBOOT-1 16.0000 RADIO-3831 15 00 19_M e-MMC-boot Mar 13 2012,20:17:28 HBOOT ------------------- SHOW BARCODE IMEI:351816051033*** SN: 123456789012 M/B Serial Number is Invalid or Empty ------------------- --------------------- IMAGE CRC osbl: 0x00 amss: 0x00 hboot: 0x00 boot: 0x00 recovery: 0x00 system: 0x00 ---------------- from the riff resurrection help: "Now phone is in bootable condition, that is, even if it does not start up normally you can flash it using known flashing methods" it does not Ok but no one method that i know does not work at all ----------------------------------------- From SD Loading [PK76IMG zip] Checking [PK76IMG zip] Parsing [PK76IMG zip] Parsing [SD ZIP] [1]BOOTLOADER -FAIL-PU [2]BOOT [3],,, Partition update fail! ------------------------------------- C:\fastboot>fastboot getvar all (bootloader) version: 0,5 (bootloader) version-bootloader: 1,16,0000 (bootloader) version-baseband: 3831,15,00,19_ (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) serialno: 123456789012 (bootloader) imei: 351816051033*** (bootloader) product: primou (bootloader) platform: HBOOT-7230 (bootloader) modelid: PK761**** (bootloader) cidnum: HTC__001 (bootloader) battery-status: good (bootloader) battery-voltage: 3905mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 94507b28 (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! With unlocked bootloader I tryed this C:\fastboot>fastboot flash recovery recovery,img sending 'recovery' (4812 KB) OKAY [ 3,058s] writing 'recovery',,, (bootloader) signature checking,,, FAILED (remote: signature verify fail) C:\fastboot>fastboot flash boot boot,img sending 'boot' (2984 KB),,, OKAY [ 2,434s] writing 'boot',,, FAILED (remote: image update error) finished, total time: 4,976s C:\fastboot>fastboot erase boot erasing 'boot',,, FAILED (remote: not allowed) finished, total time: -0,000s after i sugested to flash back my full image by DCC Read/Write but nothing changed only HBOOT and still not flashable *** UNLOCKED *** PRIMOU XA SHIP S-ON RL HBOOT-1,18,0000 RADIO-3831,19,00,120 e-MMC-boot (bootloader) version: 0,5 (bootloader) version-bootloader: 1,18,0000 (bootloader) version-baseband: 3831,19,00, (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) serialno: 123456789012 ??? not mine (bootloader) imei: *************** (bootloader) product: primou (bootloader) platform: HBOOT-7230 (bootloader) modelid: PK761**** (bootloader) cidnum: HTC__044 (bootloader) battery-status: good (bootloader) battery-voltage: 3744mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 8591a55c (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! Please help me! gl |
03-04-2014, 18:28 | #6 (permalink) |
Freak Poster Join Date: Jan 2010 Age: 14
Member: 1214273 Status: Offline Thanks Meter: 136 | Yes It's working 100% - when phone autopower in BOOTLOADER mode then need to check TP resistor. I have changed from K550 near CPU and IC Flash. Also phone has beed unlocked successfully after replace resurrection file (fixed in next version): Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (M4G1FB, 0x000091000000 Bytes = 2.27 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (M4G1FB, 0x000000100000 Bytes = 1.00 MB) Unlocking the Phone...OK Unlock complete! |
