04-08-2013, 14:33 | #2 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Hello. I have a HTC One XL Modell ID:PJ8311000 from my Customer with broken Bootloader,totally weird state of Bootloader,here is first Log via Fastboot: Code: C:\adb>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.12.0000 (bootloader) version-baseband: 0.19as.32.09.20_3 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) serialno: HT269W300216 (bootloader) imei: 111111111111111 (bootloader) product: jewel (bootloader) platform: HBOOT-8960 (bootloader) modelid: PJ8311000 (bootloader) cidnum: SPCS_001 (bootloader) battery-status: good (bootloader) battery-voltage: 3999mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-f193b42a (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.075s Log after Resurrection with PJ8312000 Dll Code: C:\adb>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.09.0000 (bootloader) version-baseband: 0.19as.32.09 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) serialno: HT269W300216 (bootloader) imei: 351860050086360 (bootloader) product: evita (bootloader) platform: HBOOT-8960 (bootloader) modelid: PJ8311000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 4047mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: e964c535 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.074s |
04-08-2013, 21:57 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Can You Send Resurrection Log...?? Because We Have PJ8312000.dll and You Have PJ8311000.Phone Also i see in first log Your Product Name is "JEWEL" But in Secound Log I see "evita" Name |
04-09-2013, 21:09 | #4 (permalink) |
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Hi. Yes totaly weird,but Device is a HTC One XL. Log: Code: [08.04.2013 14:13:32] [START OPERATION_ID = JTAG_ANALIZE] [08.04.2013 14:13:32] Open serial port...OK [08.04.2013 14:13:32] Connecting to the RIFF Box...OK [08.04.2013 14:13:32] Firmware Version: 1.34, JTAG Manager Version: 1.48 [08.04.2013 14:13:32] Selected Resurrector: [HTC OneXL (PJ8312000) V1.0.4799.51724] [08.04.2013 14:13:32] [08.04.2013 14:13:32] Connecting to the target...OK [08.04.2013 14:13:32] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [08.04.2013 14:13:32] [08.04.2013 14:13:32] Following devices are found on the JTAG chain: [08.04.2013 14:13:32] Device on TAP #0: ID = 0x4F1F0F0F, IR Length = 0x04 bits [08.04.2013 14:13:32] Device on TAP #1: ID = 0x406B50E1, IR Length = 0x0B bits [08.04.2013 14:13:32] Total IR length: 0x000F bits [08.04.2013 14:13:32] [08.04.2013 14:13:32] Analizing IDCODE(s) of the JTAG scan chain: [08.04.2013 14:13:32] 1. 0x406B50E1: Qualcomm MSM8960, H/W Rev. #4 [08.04.2013 14:13:32] [FINISH OPERATION_ID = JTAG_ANALIZE] [08.04.2013 14:13:32] [START OPERATION_ID = GET_DEVICE_ID] [08.04.2013 14:13:33] Open serial port...OK [08.04.2013 14:13:33] Connecting to the RIFF Box...OK [08.04.2013 14:13:33] Firmware Version: 1.34, JTAG Manager Version: 1.48 [08.04.2013 14:13:33] Selected Resurrector: [HTC OneXL (PJ8312000) V1.0.4799.51724] [08.04.2013 14:13:33] [08.04.2013 14:13:33] Connecting to the dead body...OK [08.04.2013 14:13:33] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK [08.04.2013 14:13:33] [08.04.2013 14:13:33] Detected dead body ID: 0x406B50E1 [08.04.2013 14:13:33] [FINISH OPERATION_ID = GET_DEVICE_ID] [08.04.2013 14:13:33] [START OPERATION_ID = JTAG_ANALIZE] [08.04.2013 14:13:34] Open serial port...OK [08.04.2013 14:13:34] Connecting to the RIFF Box...OK [08.04.2013 14:13:34] Firmware Version: 1.34, JTAG Manager Version: 1.48 [08.04.2013 14:13:34] Selected Resurrector: [HTC OneXL (PJ8312000) V1.0.4799.51724] [08.04.2013 14:13:34] [08.04.2013 14:13:34] Connecting to the target...OK [08.04.2013 14:13:34] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [08.04.2013 14:13:34] [08.04.2013 14:13:34] Following devices are found on the JTAG chain: [08.04.2013 14:13:34] Device on TAP #0: ID = 0x4F1F0F0F, IR Length = 0x04 bits [08.04.2013 14:13:34] Device on TAP #1: ID = 0x406B50E1, IR Length = 0x0B bits [08.04.2013 14:13:34] Total IR length: 0x000F bits [08.04.2013 14:13:34] [08.04.2013 14:13:34] Analizing IDCODE(s) of the JTAG scan chain: [08.04.2013 14:13:34] 1. 0x406B50E1: Qualcomm MSM8960, H/W Rev. #4 [08.04.2013 14:13:34] [FINISH OPERATION_ID = JTAG_ANALIZE] [08.04.2013 14:13:37] [START OPERATION_ID = RESURRECT] [08.04.2013 14:15:35] Open serial port...OK [08.04.2013 14:15:35] Connecting to the RIFF Box...OK [08.04.2013 14:15:35] Firmware Version: 1.34, JTAG Manager Version: 1.48 [08.04.2013 14:15:35] Selected Resurrector: [HTC OneXL (PJ8312000) V1.0.4799.51724] [08.04.2013 14:15:35] [08.04.2013 14:15:35] Connecting to the dead body...OK [08.04.2013 14:15:35] Detected dead body ID: 0x406B50E1 - CORRECT! [08.04.2013 14:15:35] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [08.04.2013 14:15:35] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [08.04.2013 14:15:35] [08.04.2013 14:15:35] Resurrection sequence started. [08.04.2013 14:15:35] Establish communication with the phone...OK [08.04.2013 14:15:35] Initializing internal hardware configuration...OK [08.04.2013 14:15:35] Uploading resurrector data into memory...OK [08.04.2013 14:15:35] Starting communication with resurrector...OK [08.04.2013 14:15:35] [08.04.2013 14:15:35] Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0100 (SEM32G, 0x00076E000000 Bytes = 29.72 GB) [08.04.2013 14:15:35] Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0100 (SEM32G, 0x000000200000 Bytes = 2.00 MB) [08.04.2013 14:15:35] [08.04.2013 14:15:35] Flashing the dead body...OK [08.04.2013 14:15:35] Resurrection complete! [08.04.2013 14:15:35] [FINISH OPERATION_ID = RESURRECT] |
04-10-2013, 20:38 | #5 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Ukraine, Lutsk
Member: 1367150 Status: Offline Thanks Meter: 42 | Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneX (PJ8310000) V1.0.4800.54064] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
04-14-2013, 07:59 | #6 (permalink) |
Member: 1367150 Status: Offline Thanks Meter: 42 | Can anyone help me? maybe its hardware problem. i have one X At&T but cant connect it. Owner says that phone died when he flash wrong boot.img via fastboot and try to get S-OFF(maybe from Evita(ONEXL)) . |
