09-11-2011, 13:41 | #2 (permalink) |
Freak Poster Join Date: Oct 2003 Location: mobile world Age: 49
Member: 42370 Status: Offline Thanks Meter: 32 | problem with my desire s.... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x002E/0x0066 (0x0086800000 Bytes) Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000008D200 |
09-12-2011, 17:18 | #4 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 1. Make sure to have all pins soldered properly, 2. Make sure to have stable power source for phone Most of errors with Desire S come out off bad soldering, or even some people don't solder GND. |
09-12-2011, 18:23 | #5 (permalink) |
Freak Poster Join Date: Sep 2003 Location: The land of rape and honey Age: 46
Member: 40118 Status: Offline Thanks Meter: 97 | I've tried on 4 or 5 pieces, it is not bad soldering. All of my Saga with the problem described here: [solved]BRICKed: inside eMMC's dead, with E:Can't open /cache/recovery/log - xda-developers main question is: can we repair it? or there is hardware malfunction of eMMC chip |
09-12-2011, 21:36 | #6 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | eMMC doesn't support bad blocks handling, hence once it gets partially damaged, it has to be replaced. Problem is, even if You replace it with blank chip, it would be impossible to boot it via JTAG since JTAG is enabled by FSBL. Blank eMMC - no FSBL, no JTAG. Dead loop. There is, though, some possibility to be explored, but not before two weeks from today. Our coder is on holidays now. |
The Following User Says Thank You to legija For This Useful Post: |
09-14-2011, 12:26 | #7 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | desire S jtag desire S all ok but not make repair Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Desire S] Resetting target...OK STATUS: Target is halted. R0 = 0xFFFFFFFF R6 = 0x00000000 R12 = 0x00000000 R1 = 0xFFFFFFFC R7 = 0x00000000 R13 = 0x00000000 R2 = 0x00000000 R8 = 0x00000000 R14 = 0x00000000 R3 = 0x00000000 R9 = 0x00000000 R15 = 0xFFFFFFF8 R4 = 0x00000000 R10 = 0x00000000 CPSR = 0x00000000 R5 = 0x00000000 R11 = 0x00000000 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Model selected: HTC - HTC Desire S Detected dead body ID: 0x17B360E1 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory.. wait always no make any operation |
09-14-2011, 16:10 | #8 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000008D200 |
09-23-2011, 10:55 | #13 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | the same problem, riff box now no solution, wait for good news from OZ. Quote:
10-02-2011, 08:28 | #15 (permalink) |
Freak Poster Join Date: Mar 2002 Age: 46
Member: 10011 Status: Offline Thanks Meter: 46 | I have also problem with resurrecting Desire S. Resurrection finishes fine, but phone wont boot, cannot enter into recovery, hboot, nothing. The phone was in boot loop after an official update, tried flashing it with an SDcard method, but the flashing froze, when it was writing the radio_v2 part. After waiting about 30min, I pulled battery, and since then I cannot make it to boot. Tried all combinations with Riff (reflash SPL, write custom CID, repair and reflash imei zone, etc...), and nothing works. Please help... d3m0n PS Here is log of operation [10/1/2011 3:15:58 PM] [START OPERATION_ID = RESURRECT] [10/1/2011 3:18:33 PM] Open serial port...OK [10/1/2011 3:18:33 PM] Connecting to the RIFF Box...OK [10/1/2011 3:18:33 PM] Firmware Version: 1.26, JTAG Manager Version: 1.35 [10/1/2011 3:18:33 PM] Selected Resurrector: [HTC Desire S] [10/1/2011 3:18:33 PM] [10/1/2011 3:18:33 PM] Connecting to the dead body...OK [10/1/2011 3:18:33 PM] Detected dead body ID: 0x17B360E1 - CORRECT! [10/1/2011 3:18:33 PM] Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK [10/1/2011 3:18:33 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [10/1/2011 3:18:33 PM] [10/1/2011 3:18:33 PM] Resurrection sequence started. [10/1/2011 3:18:33 PM] Establish communication with the phone...OK [10/1/2011 3:18:33 PM] Initializing internal hardware configuration...OK [10/1/2011 3:18:33 PM] Uploading resurrector data into memory...OK [10/1/2011 3:18:33 PM] Starting communication with resurrector...OK [10/1/2011 3:18:33 PM] [10/1/2011 3:18:33 PM] Detected an Initialized FLASH1 Chip, ID: 0x003E/0x0082 (0x0086800000 Bytes) [10/1/2011 3:18:33 PM] [10/1/2011 3:18:33 PM] Flashing the dead body...OK [10/1/2011 3:18:33 PM] Resurrection complete! [10/1/2011 3:18:33 PM] [FINISH OPERATION_ID = RESURRECT] |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
