05-18-2014, 13:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | Htc Sensation Xe Beats Z715e PG581300 confused i"ve got this model for repair i am confuse which one do i need to select at ressurector model list, at back of sticker shows Sensation Xe Beats Z715e. phone condition Black with lights on lcd screen cant detect pc port no hboot recovery.. i tried first with PG5813000 followed instruction all went fine no errors in resurrection same result after testing. Write dump file from riff box server still no luck. now i tried with PG5813001 all option selected, advance settings checked ignored target id code resurrection complete. Test phone still black screen no recovery or hboot showing on screen, i put phone on pc to usb port it was now detected only with QHSUB at device manager port. now im thinking if anyone here can share sensation xe Z715e dump so can i give a try to write on phone even a boot partition only. here's log for info of the said phone Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Sensation (PG5813001) V1.0.4557.3764] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4F1F0F0F, IR Length = 0x04 bits Device on TAP #1: ID = 0x104210E1, IR Length = 0x0B bits Total IR length: 0x000F bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x104210E1: Qualcomm MSM8260, H/W Rev. #1 |
