11-29-2013, 07:25 | #1 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1964367 Status: Offline Thanks Meter: 2 | HTC Sensation XL HTC logo HTC sensation XL I changed CID(HTC__622) to SUPERCID(HTC__001) by RIFF and tried to update European RUU RUU_RUNNYMEDE_ICS_35_S_HTC_Europe_2_31_401_2_Radio _20_70_30_0832U_3831_16_00_16_M_release_258303_sig ned_exe But after update phone has bricked Now it has a black screen with HTC logo I try to fix it by RIFFBOX but after resurrection phone still has a black screen Riff Resurrection output: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC SensationXL (PI39200) via USB V1.0.4501.57865] Looking for the HS-USB QDLoader Interface,,,OK Open the HS-USB QDLoader Interface Port,,,OK Establish connection with the Device,,,OK Uploading resurrector data into memory,,,OK Starting communication with resurrector,,,OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MAG4FA, 0x0003AB400000 Bytes = 14,68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MAG4FA, 0x000000080000 Bytes = 0,50 MB) Flashing the dead body,,,OK output fastboot getvar all: C:\fastboot>fastboot getvar all (bootloader) version: 0,5 (bootloader) version-bootloader: 1,25,0004 (bootloader) version-baseband: 3822,10,10,12_M (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2,32,708,1 (bootloader) serialno: HT29YVZ05379 (bootloader) imei: ***** (bootloader) product: runnymede (bootloader) platform: HBOOT-7230 (bootloader) modelid: PI3920000 (bootloader) cidnum: HTC__001 (bootloader) battery-status: good (bootloader) battery-voltage: 3928mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: 77020522 (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! |
11-29-2013, 22:35 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Resurect phone with JTAG Interface because this dll have a S-OFF Option -- So,Try This: 1-Solder JTAG Wires and Connect Phone To RIFF Box 2-Open "eMMC Plugin" and Load any Dump file Higher 256mb or load "Partition Info" File 3-Press "Make Partition From File" 4-Press "Repartition eMMC" --Now 5-Goto Resurrection Page and Press "Resurrect" 6-Select All Option (HBoot/Recovery/Wlan/HTC/CID/Imei) 7-Put (11111111) at CID Window....(This is superCID...not HTC_001) 8-Press "Start Resurrection) -- Now,,,,Wait for 10 min ,untill PCB little cold Try Flashing With Any GB RUU... -- After repair and phone back to work,you can update again to ICS --- Thanks |
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post: |
11-30-2013, 17:32 | #7 (permalink) | ||
Member: 1964367 Status: Offline Thanks Meter: 2 | Thank you BABAK NURI for your time! But same result when i disconnnect USB cable: What i did: 1-Solder JTAG Wires and Connect Phone To RIFF Box 2-Open "eMMC Plugin" and Load any Dump file Higher 256mb or load "Partition Info" File 3-Press "Make Partition From File" 4-Press "Repartition eMMC" Quote:
6-Select All Option (HBoot/Recovery/Wlan/HTC/CID/Imei) 7-Put (11111111) at CID Window....(This is superCID...not HTC_001) 8-Press "Start Resurrection) Quote:
I tried this GB firmware: RUU_Runnymede_hTC_Asia_HK_1.05.708.6_Radio_20.5101 .30.0822_3822.10.10.12_M_release_223083_signed.exe Instantly shows error | ||
11-30-2013, 17:37 | #8 (permalink) |
Member: 1964367 Status: Offline Thanks Meter: 2 | fastboot vars: C:\fastboot>fastboot.exe getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.25.0004 (bootloader) version-baseband: 3822.10.10.12_M (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.32.708.1 (bootloader) serialno: HT1ARVZ08793 (bootloader) imei: 358697049527253 (bootloader) product: runnymede (bootloader) platform: HBOOT-7230 (bootloader) modelid: PI3920000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3935mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: 77020522 (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.033s |
