09-18-2012, 15:24 | #3 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [HTC Tattoo V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01B00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x2F000000000000300000000000FFFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
09-18-2012, 16:09 | #4 (permalink) |
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [HTC Tattoo V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01B00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x27000000000000300000000000D00000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55BC (512MB) Reading FLASH1 address space from 0x000000000000 to 0x00000013FFFF Completed in 00:00:03.578 (Average Transfer Rate: 368.92 kB/s) Detected the HTC Partition. The SIMLOCK Zone is not Found. Now no any function work. i,m already do flash partion. |
