05-02-2012, 15:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | htc trophy plz help Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC Trophy V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - WRONG!!! ERROR: Current ID does not belong to the HTC Trophy family. htc trophy dead via upgrading process now when i try to restructor phone shows this error plz help |
05-02-2012, 22:55 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Do You Have Latest Trophy.Dll...??? Please Goto "DCC Read/Write" Page Press "Special Setting" Select "ByPass ID Check"...Then Press "OK" Resurrect Again |
05-03-2012, 13:59 | #3 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC Trophy V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - WRONG!!! ERROR: Current ID does not belong to the HTC Trophy family. restructor is new dll and bypassid checked but same error plz help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC Trophy V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - IGNORED! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x00010000000000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Invalid length. It should not be zero. when i click read memory its shows this after flash phone is ok and brand new i only upgrade to 7.5 and phone dead |
05-07-2012, 13:39 | #6 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | elected Resurrector: [HTC Trophy V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - IGNORED! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000020000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000030000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x000000040000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000050000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000060000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000070000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x000000080000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000090000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000000A0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000000B0000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x0000000C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000000D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000000E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000000F0000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x000000100000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000110000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000120000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000130000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x000000140000 is handled as Cut Excess. after check idcodecheck show this error |
05-07-2012, 13:43 | #7 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | WARNING: Programming Error (0x25) at 0x00001FEB0000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x00001FEC0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FED0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FEE0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FEF0000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x00001FF00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF30000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x00001FF40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF70000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x00001FF80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FF90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FFA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FFB0000 is handled as Cut Excess. WARNING: Programming Error (0x24) at 0x00001FFC0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FFD0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FFE0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00001FFF0000 is handled as Cut Excess. Resurrection complete! phone still dead |
05-16-2012, 02:04 | #8 (permalink) | |
Junior Member Join Date: Sep 2005 Age: 41
Member: 180123 Status: Offline Thanks Meter: 0 | same problem Quote:
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
