01-12-2013, 22:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Age: 43
Member: 978268 Status: Offline Thanks Meter: 83 | Htc wildfire problem after team i got a phone from customer with damaged imei after repairing the imei zone , phone is working normal ,but i got a strange problem when i power on, it keeps on virating till it gets fully on and then vibrating stops . and the H-BOOT version is different after repair imei before H-BOOT = 0.80.0007 now H-BOOT = 1.01.0002 any idea team |
01-13-2013, 00:13 | #2 (permalink) |
Member: 978268 Status: Offline Thanks Meter: 83 | Problem solved i got my problem solved here it is simple updated it with original shipped rom but the H-BOOT is still H-BOOT = 1.01.0002 and i want to know 1. why the H-BOOT is changed from 0.80.0007 to 1.01.0002 2. does it have any effect to phone pls reply RIFF-TEAM BR rkinfo_khan |
01-13-2013, 11:47 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | 2. That is new HBOOT and does not affect the phone, as long as is stock hboot it is OK. (there are custom hboot u know) 1. Maybe box, needs to change hboot in order to change imei. |
01-13-2013, 12:40 | #7 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi All Answer included in "Resurrection Help" So,Please Note: Quote:
if Nand memory is 4K,RIFF Box Use H.Boot "0.90.0000" if Nand Memory is 2K,RIFF Box Use H.Boot "1.03.0000" 2-Then RIFF Box Start ReWriting Model ID....And Recovery Zone So...if you have Wildefire S 4k With Any SPL X.XX.XXXX ,after resurrect You Have H.boot 0.90.0000 Also if you have other Revision ,Phone Converted to WWE Variant....This is "PG7610000’" | |
