05-16-2013, 18:49 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 43
Member: 167500 Status: Offline Thanks Meter: 16 | HTC Wildfire S Resurrect ok after flash light blinks I searched the forum and looked at the same problems but I couldn't figure it out.. Phone was ok before I just wanted to change imei because of registration law in Turkey. Resurrection was ok here is the log (Repair CID to 11111111 - Repair ime zone - Repair recovery zones unchecked - Reflash Total HTC partition during imei repair unchecked): Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC WildfireS V1.0.4522.55486] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! MARVEL PVT SHIP S-ON RL HBOOT-0.90.0000 MICROP-0451 RADIO-7.46.35.08 Apr 8 2011,17:45:10 and I flashed RUU_Marvel_S_HTC_Europe_2.13.401.3_Radio_47.23c.35 .3037_7.54.39.28M_release_236989_signed.exe While it flashes from MMC it said Main Version is older! Update Fail! So I tryed RUU_Marvel_S_HTC_Europe_2.26.401.3_Radio_47.23e.35 .3038H_7.57.39.10M_release_261695_signed.exe and flash ok : but phone blinks.. So I dissamble the phone again and erase flash(Acces Rom1 address space selected- Auto Full flash size checked) : Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC WildfireS V1.0.4522.55486] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x04010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK Completed in 00:00:08.156 (Average Transfer Rate: 64282.49 kB/s) Code: Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...FAILED ERROR: Resurrection is not Completed due to Error: 0x3901 Code: Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! When it flashes bootloader it says "Can not roll back hboot version" and again phone just blinks at the beginning and can't enter hboot.. I also flashed "WildFireS_Full_alive.bin" and "wildfire_S(2.3.5...S-OFF_Super-CID_working_Dump).bin" nothing changed. When it flashes wildfire_S(2.3.5...S-OFF_Super-CID_working_Dump).bin it stuck at %11.. Any help will be so gratefull.. Thanks |
05-16-2013, 20:11 | #2 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | All what You had to do is to untick everything but IMEI repair box. Now, since Your phone has 4kb page size, You cant just use any dump, You must use dump with 4kb page size. You can check it by opening the dump in Qualcomm plugin. 4kb page size will be detected as this: Quote:
05-16-2013, 21:44 | #3 (permalink) | |
Member: 167500 Status: Offline Thanks Meter: 16 | Quote:
Thank you for answer. Next time I will just repair imei. I have written 4kb page size dump and here is the log : Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC WildfireS V1.0.4522.55486] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x27010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK Completed in 00:43:03.672 (Average Transfer Rate: 209.26 kB/s) Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC WildfireS V1.0.4522.55486] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! | |
05-17-2013, 10:36 | #4 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | After full dump, You dont need to do any resurrection. If You set options correctly, phone should power on. You should only repair the IMEI after that. |
The Following User Says Thank You to legija For This Useful Post: |
05-21-2013, 19:52 | #7 (permalink) |
Member: 167500 Status: Offline Thanks Meter: 16 | Full erase the phone. Resurrect with all options. Tricky point make s-off with the attached zip. After that flash any rom PG76IMGsoff - Download - 4shared - rrerer efwcefr Regards |
The Following 2 Users Say Thank You to recepoz For This Useful Post: |
10-26-2013, 11:43 | #8 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
and did u repair your phone doing this same procedure as mentioned in ur post? pls inform! ihve 3pcs with the same problem, i need to repair! WBR ReyTech. Last edited by ReyTech; 10-26-2013 at 11:49. Reason: i forgot to add my pcs hve problem | |
12-13-2013, 21:26 | #10 (permalink) | |
thru sd card flashing or thru riff itself? pls do innform! WBR ReyTecvh. | |
