03-29-2012, 04:03 | #1 (permalink) |
Junior Member Join Date: Jan 2008 Location: Oldbury,west midlands Age: 39
Member: 691697 Status: Offline Thanks Meter: 0 | htc wildfire s total bricked after imei repair 1. Reflash HTC Wildfirw S with full flash WildFireS_Full_alive.rar by RIFF BOX - Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file - Check "Image Files use Used" - Check "Use Address as Offset for Flash Files" - Click "Write Flash" 2. Make resurrection 3. Flash with goldgard PG76IMG.zip now the phone doesnt come on at all my logs are below 28/03/2012 23:04:53] ------------------------------- JTAG Manager Session Opened ------------------------------- [28/03/2012 23:04:53] JTAG Manger Version: 1.41 [28/03/2012 23:04:53] ------------------------------------------------------------------------------------------- [28/03/2012 23:05:20] [START OPERATION_ID = CHECK_UPDATES] [28/03/2012 23:05:25] Connecting to the Updates Server...OK [28/03/2012 23:05:25] Getting Updates Information from the Server...OK [28/03/2012 23:05:25] Disconnecting from the Updates Server...OK [28/03/2012 23:05:25] [FINISH OPERATION_ID = CHECK_UPDATES] [28/03/2012 23:29:29] [START OPERATION_ID = GET_DEVICE_ID] [28/03/2012 23:29:29] Open serial port...OK [28/03/2012 23:29:29] Connecting to the RIFF Box...OK [28/03/2012 23:29:29] Firmware Version: 1.31, JTAG Manager Version: 1.41 [28/03/2012 23:29:29] Selected Resurrector: [HTC WildfireS V1.0.0.0] [28/03/2012 23:29:29] [28/03/2012 23:29:29] Connecting to the dead body...OK [28/03/2012 23:29:29] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [28/03/2012 23:29:29] Model selected: HTC - HTC WildfireS [28/03/2012 23:29:29] [28/03/2012 23:29:29] Detected dead body ID: 0x000000E1 [28/03/2012 23:29:29] [FINISH OPERATION_ID = GET_DEVICE_ID] [28/03/2012 23:30:56] [START OPERATION_ID = GET_DEVICE_ID] [28/03/2012 23:30:56] Open serial port...OK [28/03/2012 23:30:56] Connecting to the RIFF Box...OK [28/03/2012 23:30:56] Firmware Version: 1.31, JTAG Manager Version: 1.41 [28/03/2012 23:30:56] Selected Resurrector: [HTC WildfireS V1.0.0.0] [28/03/2012 23:30:56] [28/03/2012 23:30:56] Connecting to the dead body...OK [28/03/2012 23:30:56] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [28/03/2012 23:30:56] Model selected: HTC - HTC WildfireS [28/03/2012 23:30:56] [28/03/2012 23:30:56] Detected dead body ID: 0x203C10E1 [28/03/2012 23:30:56] [FINISH OPERATION_ID = GET_DEVICE_ID] [28/03/2012 23:31:05] [START OPERATION_ID = RESURRECT] [28/03/2012 23:32:37] Open serial port...OK [28/03/2012 23:32:37] Connecting to the RIFF Box...OK [28/03/2012 23:32:37] Firmware Version: 1.31, JTAG Manager Version: 1.41 [28/03/2012 23:32:37] Selected Resurrector: [HTC WildfireS V1.0.0.0] [28/03/2012 23:32:37] [28/03/2012 23:32:37] Connecting to the dead body...OK [28/03/2012 23:32:37] Detected dead body ID: 0x203C10E1 - CORRECT! [28/03/2012 23:32:37] Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK [28/03/2012 23:32:37] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [28/03/2012 23:32:37] [28/03/2012 23:32:37] Resurrection sequence started. [28/03/2012 23:32:37] Establish communication with the phone...OK [28/03/2012 23:32:37] Initializing internal hardware configuration...OK [28/03/2012 23:32:37] Uploading resurrector data into memory...OK [28/03/2012 23:32:37] Starting communication with resurrector...OK [28/03/2012 23:32:37] [28/03/2012 23:32:37] Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) [28/03/2012 23:32:37] Selected Resurrection Data for the NAND Chip with Page size = 2KB [28/03/2012 23:32:37] [28/03/2012 23:32:37] Flashing the dead body...OK [28/03/2012 23:32:37] Resurrection complete! [28/03/2012 23:32:37] [FINISH OPERATION_ID = RESURRECT] [28/03/2012 23:44:35] ------------------------------- JTAG Manager Session Closed ------------------------------- [28/03/2012 23:44:48] ------------------------------- JTAG Manager Session Opened ------------------------------- [28/03/2012 23:44:48] JTAG Manger Version: 1.41 [28/03/2012 23:44:48] ------------------------------------------------------------------------------------------- [28/03/2012 23:44:58] [START OPERATION_ID = GET_DEVICE_ID] [28/03/2012 23:44:59] Open serial port...OK [28/03/2012 23:44:59] Connecting to the RIFF Box...OK [28/03/2012 23:44:59] Firmware Version: 1.31, JTAG Manager Version: 1.41 [28/03/2012 23:44:59] Selected Resurrector: [HTC WildfireS V1.0.0.0] [28/03/2012 23:44:59] [28/03/2012 23:44:59] Connecting to the dead body...OK [28/03/2012 23:44:59] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [28/03/2012 23:44:59] Model selected: HTC - HTC WildfireS [28/03/2012 23:44:59] [28/03/2012 23:44:59] Detected dead body ID: 0x203C10E1 [28/03/2012 23:44:59] [FINISH OPERATION_ID = GET_DEVICE_ID] [28/03/2012 23:45:16] [START OPERATION_ID = RESURRECT] [28/03/2012 23:45:27] Open serial port...OK [28/03/2012 23:45:27] Connecting to the RIFF Box...OK [28/03/2012 23:45:27] Firmware Version: 1.31, JTAG Manager Version: 1.41 [28/03/2012 23:45:27] Selected Resurrector: [HTC WildfireS V1.0.0.0] [28/03/2012 23:45:27] [28/03/2012 23:45:27] Connecting to the dead body...OK [28/03/2012 23:45:27] Detected dead body ID: 0x203C10E1 - CORRECT! [28/03/2012 23:45:27] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [28/03/2012 23:45:27] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [28/03/2012 23:45:27] [28/03/2012 23:45:27] Resurrection sequence started. [28/03/2012 23:45:27] Establish communication with the phone...OK [28/03/2012 23:45:27] Initializing internal hardware configuration...OK [28/03/2012 23:45:27] Uploading resurrector data into memory...OK [28/03/2012 23:45:27] Starting communication with resurrector...OK [28/03/2012 23:45:27] [28/03/2012 23:45:27] Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) [28/03/2012 23:45:27] Selected Unlocking Data for the NAND Chip with Page size = 2KB [28/03/2012 23:45:27] [28/03/2012 23:45:27] Unlocking the Phone...OK [28/03/2012 23:45:27] Phone is not Locked!!! [28/03/2012 23:45:27] Unlock complete! [28/03/2012 23:45:27] [FINISH OPERATION_ID = RESURRECT] [29/03/2012 02:26:27] [START OPERATION_ID = DCC_WRITE_MEMORY] [29/03/2012 02:26:27] [29/03/2012 02:26:27] Current Settings: [29/03/2012 02:26:27] ----------------- [29/03/2012 02:26:27] Address: 000000000000 [29/03/2012 02:26:27] Length: 000000000000 [29/03/2012 02:26:27] Address Space: ROM1 [29/03/2012 02:26:27] AutoFullFlash: CHECKED [29/03/2012 02:26:27] Use End Address: UNCHECKED [29/03/2012 02:26:27] ECC Module Enabled: UNCHECKED [29/03/2012 02:26:27] Image File is Used: UNCHECKED [29/03/2012 02:26:27] Use Address as Offset: UNCHECKED [29/03/2012 02:26:27] Main (CHECKED): [29/03/2012 02:26:27] Redu (UNCHECKED): [29/03/2012 02:26:27] [29/03/2012 02:26:30] Open serial port...ERROR [29/03/2012 02:26:30] ERROR: Couldn't Detect the RIFF Box. [29/03/2012 02:26:30] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [29/03/2012 02:32:58] [START OPERATION_ID = GET_DEVICE_ID] [29/03/2012 02:32:58] Open serial port...OK [29/03/2012 02:32:58] Connecting to the RIFF Box...OK [29/03/2012 02:32:58] Firmware Version: 1.31, JTAG Manager Version: 1.41 [29/03/2012 02:32:58] Selected Resurrector: [HTC WildfireS V1.0.0.0] [29/03/2012 02:32:58] [29/03/2012 02:32:58] Connecting to the dead body...OK [29/03/2012 02:32:58] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [29/03/2012 02:32:58] Model selected: HTC - HTC WildfireS [29/03/2012 02:32:58] [29/03/2012 02:32:58] Detected dead body ID: 0x203C10E1 [29/03/2012 02:32:58] [FINISH OPERATION_ID = GET_DEVICE_ID] [29/03/2012 02:33:04] [START OPERATION_ID = DCC_WRITE_MEMORY] [29/03/2012 02:33:04] [29/03/2012 02:33:04] Current Settings: [29/03/2012 02:33:04] ----------------- [29/03/2012 02:33:04] Address: 000000000000 [29/03/2012 02:33:04] Length: 000000000000 [29/03/2012 02:33:04] Address Space: ROM1 [29/03/2012 02:33:04] AutoFullFlash: CHECKED [29/03/2012 02:33:04] Use End Address: UNCHECKED [29/03/2012 02:33:04] ECC Module Enabled: UNCHECKED [29/03/2012 02:33:04] Image File is Used: CHECKED [29/03/2012 02:33:04] Use Address as Offset: CHECKED [29/03/2012 02:33:04] Main (CHECKED): C:\Documents and Settings\Administrator\Desktop\WildFireS_Full_aliv e.bin [29/03/2012 02:33:04] Redu (UNCHECKED): [29/03/2012 02:33:04] [29/03/2012 03:39:50] Open serial port...OK [29/03/2012 03:39:50] Connecting to the RIFF Box...OK [29/03/2012 03:39:50] Firmware Version: 1.31, JTAG Manager Version: 1.41 [29/03/2012 03:39:50] Selected Resurrector: [HTC WildfireS V1.0.0.0] [29/03/2012 03:39:50] [29/03/2012 03:39:50] Connecting to the dead body...OK [29/03/2012 03:39:50] Detected dead body ID: 0x203C10E1 - CORRECT! [29/03/2012 03:39:50] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [29/03/2012 03:39:50] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [29/03/2012 03:39:50] Settings Code: 0x27010000000000000000000000000000 [29/03/2012 03:39:50] [29/03/2012 03:39:50] Resurrection sequence started. [29/03/2012 03:39:50] Establish communication with the phone...OK [29/03/2012 03:39:50] Initializing internal hardware configuration...OK [29/03/2012 03:39:50] Uploading resurrector data into memory...OK [29/03/2012 03:39:50] Starting communication with resurrector...OK [29/03/2012 03:39:50] [29/03/2012 03:39:50] Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) [29/03/2012 03:39:50] [29/03/2012 03:39:50] Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF [29/03/2012 03:39:50] Completed in 01:06:44.938 (Average Transfer Rate: 135.00 kB/s) [29/03/2012 03:39:50] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [29/03/2012 03:48:29] [START OPERATION_ID = GET_DEVICE_ID] [29/03/2012 03:48:29] Open serial port...OK [29/03/2012 03:48:29] Connecting to the RIFF Box...OK [29/03/2012 03:48:29] Firmware Version: 1.31, JTAG Manager Version: 1.41 [29/03/2012 03:48:29] Selected Resurrector: [HTC WildfireS V1.0.0.0] [29/03/2012 03:48:29] [29/03/2012 03:48:29] Connecting to the dead body...OK [29/03/2012 03:48:29] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [29/03/2012 03:48:29] Model selected: HTC - HTC WildfireS [29/03/2012 03:48:29] [29/03/2012 03:48:29] Detected dead body ID: 0x203C10E1 [29/03/2012 03:48:29] [FINISH OPERATION_ID = GET_DEVICE_ID] [29/03/2012 03:49:39] [START OPERATION_ID = RESURRECT] [29/03/2012 03:51:36] Open serial port...OK [29/03/2012 03:51:36] Connecting to the RIFF Box...OK [29/03/2012 03:51:36] Firmware Version: 1.31, JTAG Manager Version: 1.41 [29/03/2012 03:51:36] Selected Resurrector: [HTC WildfireS V1.0.0.0] [29/03/2012 03:51:36] [29/03/2012 03:51:36] Connecting to the dead body...OK [29/03/2012 03:51:36] Detected dead body ID: 0x203C10E1 - CORRECT! [29/03/2012 03:51:36] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [29/03/2012 03:51:36] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [29/03/2012 03:51:36] [29/03/2012 03:51:36] Resurrection sequence started. [29/03/2012 03:51:36] Establish communication with the phone...OK [29/03/2012 03:51:36] Initializing internal hardware configuration...OK [29/03/2012 03:51:36] Uploading resurrector data into memory...OK [29/03/2012 03:51:36] Starting communication with resurrector...OK [29/03/2012 03:51:36] [29/03/2012 03:51:36] Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) [29/03/2012 03:51:36] Selected Unlocking Data for the NAND Chip with Page size = 2KB [29/03/2012 03:51:36] [29/03/2012 03:51:36] Unlocking the Phone...FAILED [29/03/2012 03:51:36] ERROR: Unlock was not Completed due to Error: 0x3901 [29/03/2012 03:51:36] [FINISH OPERATION_ID = RESURRECT] [29/03/2012 03:51:47] [START OPERATION_ID = RESURRECT] [29/03/2012 03:52:42] Open serial port...OK [29/03/2012 03:52:42] Connecting to the RIFF Box...OK [29/03/2012 03:52:42] Firmware Version: 1.31, JTAG Manager Version: 1.41 [29/03/2012 03:52:42] Selected Resurrector: [HTC WildfireS V1.0.0.0] [29/03/2012 03:52:42] [29/03/2012 03:52:42] Connecting to the dead body...OK [29/03/2012 03:52:42] Detected dead body ID: 0x203C10E1 - CORRECT! [29/03/2012 03:52:42] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [29/03/2012 03:52:42] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [29/03/2012 03:52:42] [29/03/2012 03:52:42] Resurrection sequence started. [29/03/2012 03:52:42] Establish communication with the phone...OK [29/03/2012 03:52:42] Initializing internal hardware configuration...OK [29/03/2012 03:52:42] Uploading resurrector data into memory...OK [29/03/2012 03:52:42] Starting communication with resurrector...OK [29/03/2012 03:52:42] [29/03/2012 03:52:42] Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) [29/03/2012 03:52:42] Selected Resurrection Data for the NAND Chip with Page size = 2KB [29/03/2012 03:52:42] [29/03/2012 03:52:42] Flashing the dead body...OK [29/03/2012 03:52:42] Resurrection complete! [29/03/2012 03:52:42] [FINISH OPERATION_ID = RESURRECT] |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
