01-14-2013, 11:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Huawei c2930t new flash chip inside after flash with riff set dead AFTER FLASH WITH RIFF SET DEAD AND FLSHING IS VERY SOLW IN NEW CHIP TIME 20 MIN Detected an Initialized FLASH1 Chip, ID: 0x0001/0x007E (8MB) Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [QSC1100 X14 NOR V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x26010009000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0001/0x007E (8MB) |
01-14-2013, 11:27 | #2 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
About Speed Matter Check This In Your Logs.. Code: Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x26010009000000000000000000800000 Puneet5154 | |
01-14-2013, 11:52 | #3 (permalink) | |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
i hve 2 set in hand hang on tata logo after flash with riff set dead i already try speed sample a max speed but its time taken 20 min and then i try with other 2930t set its flash time is 3 to 5 min only and set is working well | |
07-04-2013, 04:23 | #6 (permalink) | |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | same condition pls any body help me Quote:
same condition pls any one reply thise solution.... | |
02-20-2014, 06:01 | #12 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | i have dump contact my yahoo...... [email protected] i have dump 2830 new chip flash file & 2930t new chip dump file |
06-16-2014, 13:05 | #13 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | 2830 & 2930t new flash ic file afte dead recover tested file 2930t new chip ic - Download - 4shared - ashish gupta |
The Following User Says Thank You to ashish800 For This Useful Post: |
07-26-2014, 12:56 | #14 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | thanks good file set is ok Quote:
