02-17-2014, 19:00 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | Huawei G300 - U8815 riff resurect failed Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei U8815 V1.0.4723.8563] Connecting to the dead body...OK Detected dead body ID: 0x106230E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. I try diferent speed from 20 khz to maxim ... same result. Wire ar 10 cm from box to phone.... Where is problem? Br Mihnea |
02-17-2014, 22:24 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Whenever You have such error, first thing to do is to check NRST and GND pins. If both are connected properly, and error persists, that means device hardware is bad, and RAM cannot be initialized. |
12-15-2014, 21:25 | #5 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
btw. Legija already wrtote that ... b.r. Alex | |
