07-07-2013, 12:17 | #1 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Slovakia Age: 39
Member: 17405 Status: Offline Thanks Meter: 345 | Huawei U8815 any help would be greatly appreciated Quote:
phone can connect via usb as HS-USB Diagnostics port Last edited by blinet; 07-07-2013 at 12:24. | |
07-08-2013, 08:18 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Read:RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. |
10-02-2013, 09:13 | #4 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.52 Selected Resurrector: [Huawei U8815 V1.0.4723.8563] Connecting to the dead body...OK Detected dead body ID: 0x106230E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Set I/O Voltage reads as 2.61V, TCK Frequency is 1 MHz Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] ERROR: No response from the RIFF Box. Last edited by glontz; 10-02-2013 at 09:18. |
11-06-2013, 16:42 | #5 (permalink) |
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | another phone same problem Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei U8815 V1.0.4723.8563] Connecting to the dead body...OK Detected dead body ID: 0x106230E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
11-19-2015, 10:07 | #6 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Deira, Dubai
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | ? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8815 V1.0.5256.55735] Connecting to the dead body...OK Detected dead body ID: 0x106230E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
