03-12-2014, 14:46 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Kosova
Member: 87568 Status: Offline Thanks Meter: 101 | Same problem, after sucessfull resurection phone still not power on or get download mode. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei Y300 V1.0.5179.41132] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3.64GB Flashing the dead body...OK Resurrection complete! |
03-28-2014, 08:37 | #4 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: COLOMBIAA
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | Quote: i try write flash backup from support but not work i try ata lenght ,, file size ,, an use aress Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei Y300 V1.0.5179.41132] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x20010000000000000000000045CF0000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) Writting FLASH1 memory from 0x000000000000 to 0x000045CEFFFF ERROR: DCC Loader has reported Error Code = 0x3E (0x012000 <> 0x012000) Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei Y300 V1.0.5179.41132] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x25010000000000000000000045CF0000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) ERROR: Image file size wrong. Main and Spare not correlate in size. please help me thxs | |
03-28-2014, 08:49 | #5 (permalink) |
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | Y300--0151 IS MY PHONE Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei Y300 V1.0.5179.41132] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3,64GB Flashing the dead body...OK Resurrection complete! but not enter download |
08-04-2014, 18:42 | #6 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | the same problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei Y300 V1.0.5179.41132] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00A, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00A, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3,64GB Flashing the dead body...OK Resurrection complete! |
08-20-2014, 18:56 | #8 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: Dominican Republic
Member: 1607116 Status: Offline Sonork: 100.1617729 Thanks Meter: 52 | Quote: | |
09-09-2014, 07:06 | #11 (permalink) |
Freak Poster Join Date: Oct 2007 Location: GOA
Member: 600436 Status: Offline Thanks Meter: 219 | huawie y300 hard reset problem plaesse help me sor huawie ascend y300-0151 patton lock Huawei Ascend Y300 Hard Reset and Huawei Ascend Y300 Factory Settings Method is here. Huawei Ascend Y300 Hard Reset Utilizing Control Buttons Switch off your Android mobile phone Huawei Y300 smartphone or pull out battery pack and re insert is right after a fews secs. Press and hold both Volume... |
10-25-2014, 15:55 | #13 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Krusevac, Serbia Age: 56
Member: 58263 Status: Offline Thanks Meter: 19 | Same problem, after sucessfull resurection y300-0100 phone not power on or get download mode. Can somebody upload Huawei Ascend Y300-0100.bin, because I can't download it from Legia's forum. B.R. Nenad |
