11-17-2011, 13:43 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Iran
Member: 299773 Status: Offline Thanks Meter: 15 | I cant repair boot S5570 Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [Samsung S5570] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x0000010020000000000000000027 Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. plz hellp me |
11-19-2011, 14:02 | #3 (permalink) |
Member: 299773 Status: Offline Thanks Meter: 15 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [Samsung S5570] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 4 MHz Settings Code: 0x0C09010020000000000000000027 Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [Samsung S5570] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Settings Code: 0x0C00010020000000000000000027 Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. plz hellp me |
11-19-2011, 14:14 | #4 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Read sticky topics ! http://forum.gsmhosting.com/vbb/f634...dated-1383804/ |
The Following User Says Thank You to legija For This Useful Post: |
11-19-2011, 14:59 | #5 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | Quote:
are you using usb cable only to power phone? use battery and keep press the power button until ressurrection is finish. | |
The Following User Says Thank You to rea1One For This Useful Post: |
12-11-2011, 22:03 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 41
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | got this problem every other thing connection etc ok reading info ok jtag chain ok get id ok checked on other MHZ same problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [Samsung S5570] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x006C/0x0082 Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x30 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x30 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x30 (0x000000). Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x0000000000 best regards NeOrElOaDeD AKA XpErTs GsM |
12-22-2011, 06:49 | #10 (permalink) | |
Junior Member Join Date: Aug 2010
Member: 1357854 Status: Offline Thanks Meter: 2 | Quote:
12-22-2011, 10:34 | #11 (permalink) | |
Insane Poster Join Date: Jul 2011
Member: 1621733 Status: Offline Sonork: 100.1606087 Thanks Meter: 4 | Quote:
12-31-2011, 13:09 | #13 (permalink) |
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | connectivity.its the hardware problem and if any of u can understand it doesn't connect and read or write the zero sector. ssssoooooo guy use the thing called brain :P~ |
02-02-2012, 14:53 | #14 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Indonesia
Member: 69608 Status: Offline Thanks Meter: 63 | need help samsung GT s5570 dead after failed resurection Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung S5570] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
The Following User Says Thank You to virgix For This Useful Post: |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
Contact Service Repairer 1.2 by Bartek | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2011 09:00 |
Phone not respond! (Load boot data) Need a help ! | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-23-2001 02:10 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
cant unlock CSI eeprom | Stryker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-20-2000 13:00 |
